Question about Samsung Refrigerators
Rs253baww Not freezing
What's the freezing phase in the freeze-drying process?
The main stages of the freeze-drying process are placing the material in the freeze-drying flask, rotate the flask in a bath which is cooled by mechanical refrigeration in a larger scale freezing is usually done using a freeze-drying machine
Aug 09, 2012 | Camping, Backpacking & Hiking
Rs253baww stopped working
Stinkerbelle, im not sure i understood your problem,
You are sayint it is freezing the food, when it is not in the freezer?
Jan 02, 2008 | Samsung RS2534 Side by Side Refrigerator
How do you reset the digital panel on the samsung side by side rs253baww
Unplug the unit for 5 minutes then plug it in.. If this doesnt help you need to contact Samsung.
Feb 16, 2011 | Refrigerators
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
I have a Samsung model RS253BAWW side by side I no longer can get water out of the cold water supply in the door. I changed the water filter and that did not cure my problem. When I changed the filter, I...
This sounds like you may have a freezing problem, there is a water tank heater and a water line heater in the system, could also be the water valve at the door. I say someone selling a repair service manual on the online auction place E b a y that may help you further troubleshoot the problem.
Jan 23, 2011 | Samsung RS2534 Side by Side Refrigerator
Control panal is not working.
Hold Energy Saving & Lighting buttons simultaneously for 10 seconds! Panel dispaly resets.
Mar 31, 2010 | Samsung RF265AA Bottom Freezer French Door...
Fridge Temperature wont stop blinking
I had the same prob, you need to defrost it until No MORE water drips out of the drain pipes located at the back ( there should be 2 of them one for fridge one for the frezzer, make sure the rubber thing at the top of the pipe is not closed up- if it is cut it open ) when you think its defrosted place a cup under these pipes and leave it for a few more hours, if there is ANY more water in there your not defrosted yet and it wont work--- Leave the doors open of course, mine took almost three days and i live in a hot climate.
ok once you have done that, take the cover off for the main circuit board ( top of the fridge ) on the circuit board there should be a little black button with "test" on it hold that in and turn the fridge on. it should beep at you ( wait 5 sec ) then push it again ( beeps again, wait 5 sec ) push it again, you have to do it about 3-4 time before it stops beeping, when its stopped, just leave it, it should start up after a couple a mins.
the fridge will take much longer to get cold so be patient, if you find it flashing again push that test button, i just played round with mine and it came right, good luck, because the only other way round the prob is to turn it off at the wall and turn it back on.
Sep 28, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerator door doesn't close
I ended calling a pro. The problem wasn't with gasket or hinge but with a tube that had ice deposited on it. This pushed my drawers towards the door and that prevented the door from closing. As epr him; it's a common problem with this Samsung model.
Sep 21, 2008 | Refrigerators
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
13 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
