Question about Acer AL1716 F Monitor
When i turn on my acer p201w monitor it comes on for a second or two then powers down
4 Suggested Answers
  • 152 Answers
SOURCE: power supply on 17" acer monitor
franh, Typical of a lcd/fpd monitor! There is nothing you or hundreds of others can do to repair it all by yourself. I have repaired 3 monitors and helped tutor 2 others on fixya with their monitors. All had same exact symptom as your monitor. I need you to do a simple test for me. With failed Acer monitor near to your Fully Booted PC with a known good desktop being displayed on back-up monitor, quickly swap out the monitor cables from the back of the PC. Keep touching the CTRL key on you keyboarb every 30-50 seconds to keep the PC from sending out sleep mode command to monitor while doing the reconnect of acer to your PC monitor output port. Make sure the Acer also is connected to a live wall outlet/power strip. Turn on the Acer and note what happens. If screen shows a sharp clear image for a second, then goes black, do the following. Get a bright flashlight and shine it on the screen from a distance of 1 or 2 inches and tell me if you can see the desktop display. get back to me with your observations. I'm louie12fix on fixya or lmistyrel@ aol.com.
Posted on Apr 05, 2009
  • 5 Answers
SOURCE: monitor ACER 24" stop display after few seconds
This is not a Fix to the Problem, If you read some of the other "fixes" that relate to this you will see that it is a more serious problem and one that Acer should Do the Honorable Thing and have a Recall.
I actually went in side on three of the Same Monitors and one that was a 21 inch and found the problem is "HEAT"
You can see where a Board actually shows Browning on the Circuitry I am Going to try to order a new board P/N:AS08B360411.
I will update as soon as work is completed.
Posted on Mar 18, 2010
budmrtn
  • 11361 Answers
SOURCE: the green power light comes on, but the monitor
Check for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 03, 2010
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
My acer travel mate 2000 powers up fine but the monitor is black any solutions?
You can try this:
-Turn off
-Remove battery and remove ac power cable
-Hold down power button without cable and battery for 60 seconds
-Connect your power cable and push power button
Try with another monitor if possible. It may be motherboard issue or bad connectors.
Jun 04, 2015 | Acer Computers & Internet
Acer p201w monitor
go to this link should help you out.... how to set display Acer p201w monitor Google Search ...There is no difference in changing the display on an Acer monitor and on a monitor from another company.
  1. Access the desktop of your computer and right click the screen. ...
  2. Click on the "Settings" tab that is on the top-right corner of the "Properties" window. ...
  3. Adjust the resolution and color to your preferences.
How Do I Change the Display on an Acer Monitor? ' It Still Works ...
Oct 24, 2017 | Computers & Internet
What is the screen resolution for acer al1716 monitor
Hold the power button down for at least 10 seconds till the light goes out, then turn it on and the problem is gone.
May 16, 2010 | Acer AL1716 17" LCD Monitor
Acer monitor AL1706 Power On problem
You are more likely to have bad capacitors problem in the power supply, inverter circuits. I would look for bad caps first. Look at some of the sample here: http://s807.photobucket.com/home/budm/allalbums
Jan 02, 2010 | Acer AL1706AB LCD Monitor
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
Power supply on 17" acer monitor
Apr 05, 2009 | Acer AL1916W 19" LCD Monitor
Acer Al 1711 Monitor
Turn the monitor ON and continue to hold the power button for a few seconds.
Worked for me :)
Nov 09, 2007 | Acer AL1711 17" LCD Monitor
Monitor comes up shows "acer" then says no signal and goes black
1 Take the monitor out to the street
2 Raise above head
3 Hurl it twards the ground
4 Release
5 Watch peices fly everywhere
6 Enjoy a cold beer
7 Go out & buy a nice new monitor ( not a acer product )
Feb 18, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1716 F Monitor Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
