Question about Holmes Products Holmes HT35R-U Tower Fan With Remote Control
I have a floor fan and the remote isn't working.
I have a floor fan and the remote ireciever isn't reconizing the remote. i have another fan exactly like it and the remote works on both. so i know it's not the remote. is there a way to sync the remote to the fan?
  • 378 Answers
Check IR receiver on the fan circuit board, resolder the lead.
Posted on Jun 19, 2009
Remote doesnt work anymore
Fan remote stopped working. New battery installed.
Apr 14, 2013 | Lakewood HV 18-c Floor / Box Fan
I've just bought a new remote control as the original isn't working. Is there a set up routine that one has to follow?
If you bought exactly the same remote, then it should work without doing anything (just make sure it has batteries) if you bought a Universal Remote, you should input the codes for Panasonic first.
Sep 24, 2011 | Panasonic DMR-E55 DVD Recorder
Romote control is not working.there is a battery in it ,red light comes up but fan is not reponding.is there any way i can manually control the fan ,any button hided some where? or i can make sure remote...
normally in Hunter fans its not the controller but the receiver goes out, if your controller has a new battery and the receiver doesn't get the signal,, the fan isn't going to work, I've never been able to Locate Hunter receivers, tons of the remotes, you can contact them on line at this link
http://www.huntershoponline.com/cc_contactus.asp
Aug 26, 2011 | Hunter (25417) Ceiling Fan
Remote isn't working
I asume you checked the battires these remote go out quit offten there is a cirut board in the fan you need to check this out if it is bad the board will have a burnt spot on it if dose the board is bad you will just need to go to lowes or home depot and get a new one there about 50 dollars good luck.
Aug 21, 2011 | Hampton Bay 70212 Sabitini Ceiling Fan
Remote will not operate fan or light. Replaced battery. Remote light glows red when pressed
Check dip switches in remote and dip switches on receiver in the canopy of the fan, make sure the settings match exactly. Make sure there is power to the fan. Make sure the fan and light are not manually set to off by pullchains that may be on the fan. If the fan does have pullchains, wire it directly in (bypass the remote in the canopy) and test the functions to make sure the fan and light are working. If it works without the remote, but not with the remote, and the dip switches are set the same and you have new batteries, then the remote and receiver should be replaced.
Feb 28, 2011 | Hunter 52" Ceiling Fan With Light And...
Remote control will not turn on/off fan or light. Has good battery. Where is the transmitter located on the ceiling fan?
The transmitter is the remote. The receiver is located inside the fan mounting bracket next to the ceiling. If you replace it make sure to set the dip settings on the new receiver exactly as they are on the old one. Wire the new receiver exactly as the old one is wired if it was working before.
Nov 07, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote control for the fan
So you have Hampton Bay fans and universal remotes? If so, then either the remotes are not programmed correctly or the receivers are not wired for the remotes. That is one bad thing about using universal remotes.
I suggest you go to Home Depot and buy one Hampton Bay remote, bring it home, turn of the breaker to the fans, and get on a ladder to get to the receiver. Check the dip switches, and program the switches on the remote exactly the same way.
(While you're at it, make sure the universals dip switches are set exactly the same.)
It should work properly after that.
Sep 13, 2008 | Universal Remote Control Hampton Bay...
Ceiling fan remote not working
It is certainly possible that the remote went bad -- after all, it is an electronic device, and is was "made in China". With that said, there are other possibilities:
* The receiver, which is what receives the signals sent by the remote control, could have died. In most remote-controlled fans, the receiver is located in the ceiling canopy (the decorative part up by the ceiling, which hides the wires). In other fans, it's located in the switch housing (the part of the fan to which the light kit attaches). Solution: try everything else on this list; if nothing works, replace the receiver. Universal replacements for most models are available at Home Depot and Lowes.
* A wire on that receiver could have come loose. Solution: check all wires for secureness.
* A wire in your wall or ceiling -- the wire which provides power to the fan -- could have come loose or been chewed through by a rodent. Solution: use a circuit tester to check whether there's power at the connections at the top of the fan, in the ceiling, where the fan connects to the building's wiring.
* A circuit breaker could have tripped or a fuse could have blown. Solution: check your circuit breaker or fuse panel.
* The DIP switches inside the remote control -- which set the frequency on which the control transmits -- could have been knocked out of position accidentally or by a child playing with it. Solution: check the code on the DIP switches on the receiver in the fan -- then, make sure the remote control has its DIP switches set the exact same way.
If none of the above work, then yes -- the problem is with the receiver or the transmitter (remote). The two are typically sold as a pair, and universal replacements are available at Home Depot and Lowe's.
Hope that helps! Feel free to ask for clarification if you need it!
Jun 16, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
372 people viewed this question
Top Holmes Products Dryers Experts
Morne Olivier
Jay Finke
Jay Finke
ray gallant
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
