Question about Brother MFC 7420 All-In-One Laser Printer
Brother MFC model reading ''back cover open'' but cover in place correctly?
  • kgosling Jun 19, 2009
    where is the switch/sensor?
    President:
  • 2,187 Answers
You have to check on the switch/sensor at the cover which detects if it is shut or not. Something may have been blocking it and may need cleaning or it could be the switch may have been disconnected to the board because of faulty wiring. If it all checks out, you may want to check on the board there may be a fried part.
Posted on Jun 19, 2009
  • Nicolo Carlo Parazo Jun 19, 2009
    Try these:
    1. open the back cover
    2. pull the flap down which hides an orange roller on the fuser (be carefull this may be hot)
    3. find the thin piece of plastic that runs from the middle to the right hand side. That is the source of the problem.
    4. 3/4 along the right hand side, there is a sticky out bit on this bar that should sit in a hole.
    In most cases this is not located properly which causes the error. See if it helps. Otherwise it could be an issue with the board.
Reset brother toner counter mfC 7360N
If you are using refilled products then your re-manufacturer needs to reset the cartridge. For these there is a particular gear placement to allow the toner sensor to reset. If you are using Brother Original products then the brother helpdesk should talk you through this.
If you are filling your own cartridges well any issues you have with this reset process are at your own risk.
Once you have completed the reset process go to the brother website and download the latest firmware update for your machine as this will alleviate most of the issues with cartridges not being correctly set.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:10.0pt;"Times New Roman";}
  1. Open Front Cover.
  2. Display reads "Front Cover Open"
  3. Press the 'Clear' button
  4. Display reads "Replace Drum"
  5. DO NOT RESPOND TO THIS MESSAGE. Press '*, 0, 0' on the keypad.
  6. Press 'OK'
  7. Close Front Cover.
your machine should now be ready to print.
Aug 31, 2014 | Brother MFC 7360N - Multifunction fax /...
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
I cannot find the slot to replace ink cartridges! Brother LC61CL
Which Brother all-in-one printer or copier do you have? The LC61CL cartridges fit MFC-255CW, MFC-290C, MFC-295CN, MFC-490CW, MFC-495CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-795CW, MFC-990CW, MFC-J410w, MFC-J615W and the DCP-165C . The cartridges could fit other printers as well.
I know that the MFC_795CW has a cover on the right hand side that you need to open when the unit is on. Then the cartridge carrier will move to the ink changing area. (For a new printer, there is a green protector in place that you need to pull out. Keep this in case you move the printer later.) This location applies for the DCP-165C copier as well.
If the unit is on but the cartridge carrier does not move to the opening of the ink cartridge cover, then something may be blocking the carrier from moving. This could be a scrap of paper or other foreign object blocking the route.
Brother has the support for most of their printers available here: http://www.brother-usa.com/Support/ . There is a specific link for just the manuals on the page as well.
More complete trouble-shooting guides are available if you search for your model from the Brother search box at the top right hand corner of the page. Go to the product details page and then see the Brother Solution Center links on the right hand side of the page.
I hope this helps.
May 05, 2011 | Brother Office Equipment & Supplies
Back door open but it is not. what do I do?? The above solution didn't work. Everything seems to be in place.
If every cover had been closed correctly, then sounds like you have a paper jam in the rear.
Feb 21, 2011 | Brother MFC 7420 All-In-One Laser Printer
How to reset the drum on a Brother 7840
Remove old drum from the unit.
Remove toner and install in the new drum.
Place Drum Back in the machine, leave cover open.
With the cover door open Hold Clear/Back button (about 5 sec.) until the Lcd reads Replace/Reset Drum? yes? no?
Press 1 for yes and close cover.
The machine will cycle and restart, once it says ready the counter has been reset to 100%
Feb 18, 2011 | Brother MFC 7840W Printer
Brother all-in-one printer not working; error 'back door open'
Open the front cover and remove the drum and toner.
There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Jun 02, 2010 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-7220 says close back cover but it's already closed
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
May 13, 2009 | Brother IntelliFax-2820 Laser Fax
Refill toner Brother MFC 7420
open front cover, press OPTION button, on the LCD will appear a message "NEW DRUM?" ....DO NOT RESPOND....just type on the keyboard "*00" and there will appear a message "Accepted" and use it in your pleasure.
PS. in any case i blocked with paper labels the viewing windows from transparent plastic on the toner itself....
Mr. Brother, do not try to be smarter than your customer
May 22, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 845 CW Paper Jam
which two digit error code does the machine display despite paperjam?
Mar 25, 2008 | Brother MFC-845CW multi-function...
Brother MFC 7420 All-In-One Laser Printer Logo
23 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
