Question about Samsung Televison & Video
Need Samsung led remote no BN59-00871A
My LED remote is not functional and need a new remote..... The remote no is BN59-00871A
  • 56 Answers
SOURCE: I just connected a new Samsung LED/LCD TV. I am
programm the remote to your tv by pressing the TV button till all lights light up at the top then enter your 3 digit tv code ( samsung codes are 738, 516 or 680 then press pound. this should enable you to controll power and volume, be sure to press sat to operate you dish recvr.
Posted on Nov 12, 2009
SOURCE: Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Posted on Dec 21, 2009
  • 5 Answers
SOURCE: On my Samsung LED TV Series 6 I can't use my remote to
You should be able to receive a replacment remote under your limited parts warranty. If not, there are several resources on the web.
Posted on Mar 10, 2010
budmrtn
  • 11361 Answers
SOURCE: Brand new 55" Samsung LED
Well, you may have problem inside the TV, to find out for sure is to use this remote with SAMSUNG TV in the store where you bought it from, if it works, then I would demand them to give you a new TV since it may be a LEMON set which I would not want to own if it breaks down already, if the remote does not work in the store then ask the store to give you a new one.
Please leave rating if it helps.
Posted on Jan 20, 2011
sodeep
  • 3267 Answers
SOURCE: Need the universal remote code
check it out here
Posted on Jun 19, 2011
Samsung led tv 5003 remote channel selector not working, must use cable company remote. Volume only works on samsung remote.
The cable company remote will have under settings a program code function for the remote. Setting the Samsung code will enable the cable remote to adjust the volume. Many TVs have more than one code. You may need to try several to get the right one.
the attached images are examples of this process. Your remote supplied from the cable provider will have its own unique process. Consult the info supplied with the remote. Access the help feature available with some cable services. Your cable provider may have the help function available on their Website.
Hope this helps?
Sep 28, 2016 | Samsung Televison & Video
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
Can't find the "wireless remote control" on my
hi,
LE-46B650T not support wireless remocon.
Only model C series already supported.
Mar 21, 2011 | Samsung LE-46B650T 46" HDTV-Ready LED TV
Not Workind Want to repair it or replace it with a new one
Try website like Remotes.com to buy an exact new one or very closed to the original.
Feb 24, 2011 | Samsung Televison & Video
REMOTE CONTROL HAS STOP OPERATING ALL FUNCTIONS
You only need to replace the Infra Red LED ( remote sensor) including Filter with code CF 455E spare part, usually is the yellow ones..hopefully help.
Oct 14, 2010 | Samsung HL-S5687W 56" HDTV
Samsung CXM1374 TV/VCR COMBO. The original rmote no longer functions. Changed batteries but still no functions work. Does remote or TV buttons have to be activated to reprogram?
you need to open the cover of your remote control..visually inspect the PCB for any loose connections/cracked board specially the battery terminals...solder any loose connections and if nothing happens replace the crystal oscillator from the remote control it is a square,color orange sometimes blue with a label on it its clock speed in MHZ. it is available at electronics supply store..you can use the camera of your cellphone to test whether the remote is working by just pointing the camera to the LED at the top of your remote once you press a button from the remote the LED should lit...means your emote is working...3rd test the LED/infra red if it is not busted..remove the LED INFRA RED from the pcb and using a multitester analog supply.set the tester to X1 range then supply the terminals positive negative with the test probe there should be a continuity connection and the LED should be lit.
May 20, 2010 | Televison & Video
Need code for Urc-3021 for memorex dvd player
I recommend using the auto-search function to find the code for your Memorex DVD player.
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your DVD:
  1. On the remote control, press DVD once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 28, 2009 | One For All URC-3021 Remote Control
TV won't turn on
you need a new lamp. the error is for dead lamp
Apr 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Televison & Video Logo
22 people viewed this question
Jerry Greenberg
Jerry Greenberg
