Question about Microsoft Flight Simulator 2004 Update
Loaded but wont run when activated - Microsoft Flight Simulator 2004 Update
  • 790 Answers
Check this link for more info...
Also don't know your OS ?
Flight Simulator 2004 doesn't run correctly on Windows 8. It runs on my Windows 8 laptop bought in April 2013. But, none of the aircraft, including any add-ons, show up in the preview window - it is always black. Also, If I download weather and try to save a flight, when I go back to that "saved" flight, it always reverts to the default flight with the Cessna @ the default airport. If anyone knows how to make the flights save, on the Windows 8 platform, please let me know - likewise, with the aircraft previews. Flight Simulator 2004 did quite well on the Windows XP platform for me.
Posted on Apr 26, 2014
07 chevy uplander ran out of fuel,with 1/8 tank on way,to store now the battery save active displays when I attempt to start the van like,it set off an alarm. How can I get it running
Battery Saver Active
Refer to Charging System Description and Operation
The BATTERY SAVER ACTIVE message will display on the driver information center (DIC) when the vehicle enters a load shed 2 event. Refer to Load Shed System Description and Operation for load shed 2 setting criteria.
Electrical Power Management
The electrical power management (EPM) is used to monitor and control the charging system and alert the driver of possible problems within the charging system. The EPM system makes the most efficient use of the generator output, improves the battery state-of-charge (SOC), extends battery life, and manages system electrical loads.
The load shed operation is a means of reducing electrical loads during a low voltage or low battery SOC condition.
The idle boost operation is a means of improving generator performance during a low voltage or low battery SOC condition.
Each EPM function, either idle boost or load shed, is discrete. No 2 functions are active at the same time. Idle boost is activated in incremental steps, idle boost 1 must be active before idle boost 2 can be active. The criteria used by the body control module (BCM) to regulate EPM are outlined below:
I dought you will be able to get it running , except by luck . The best thing you could do is have a qualified repair shop diagnose it . The first place to start would be to hook up to a factory diagnostic scan tool , Check for DTC'S - diagnostic trouble codes .
Jan 28, 2017 | 2007 Chevrolet Uplander
WATER FILLS WONT SHUT OFF
The pressure swith (load size) is what controls that chang that. A small hose runs from the bottom of your tub and as the water fills a measerd amount of water fills that tube and pressure build up in their operates that switch and activates the timer to stop filling and start agitating.
Jun 06, 2010 | Kenmore 24032\24036 Top Load Washer
My machine wont drain the water or go to the spin
Drain Vlve command no activated. Or The valve is faulty. Check wiring also.
Mar 28, 2010 | Indesit W 123 Front Load Washer
Background wont load and cant loador remove Active Deskstop
hi, your OS or windows was corrupted that is why you can't get or load your background the solution of that is to reinstall your operating system so that it will go back to normal.
Mar 20, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
Background wont load or either remove Active Deskstop
Hi friend,
For active desktop please follow the given steps and surely you find the solution,
Firstly click on the start button and go to RUN option.
Type regedit and press ok, Registry window will be open. Than follow the steps-
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Desktop\Safe Mode\Components
Change the value of DeskHtmlVersion to zero instead of decimal 272.
After that press F5 button of keyboard few times or restart the system
Good luck,
Thanks
Cant play farmville it wont load ???
Try loading it from another website. Some have so much junk running that it prevents the games from loading.
Make sure you have the active-X loaded.
Feb 17, 2010 | Facebook Computers & Internet
Vgn-fw330j/b wont stay in sleep mode. it awakens by itself.
I know when you have it in hibernation it will come out if simething startsto run in he background. This could be malicious software or just something you have running that activates and brings it out of hibernation. How many things load up when you first start up the computer, you should eliminate all the programs that start when you boot up, you only need to run programms when you want them, see if this solves your problem
Sep 28, 2009 | Sony VAIO VGN-FW230J/B Notebook
Lg viewty activate Java Settings
I have a boost mobile game phone d615 and when i go to download ebuddy it says you need to activate your jave settings or it will say out of memory but i have deleated all my songs
Sep 27, 2009 | LG KU990 Viewty
Vista,can not down load active x
Do the following.
Repair your PC via the Windows installation DVD
Then again download the required activeX controls.
In this way you wont lose your data either and the problem would also be solved.
Thank You
Please rate my solution
Jan 14, 2009 | Computers & Internet
Door won't open
Check your instruction manual to see if there is a childlock feature that has been activated.
Is there water in the machine or has it completely rinsed out?
If you switch the power off and wait a couple of minutes, can you then open the door with the power still off?
Sep 25, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Computers & Internet Logo
211 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
