Question about Air Tools & Compressors
Need manual for a Kawasaki model 840703 5gal 3hp
Need manual for a Kawasaki model 840703 5gal 3hp twin tank air compressor
I called 1 800 590-3723 and they are e-mailing a manual to me. For my model (3HP twin tank) they said 10W30 or 5W30.
Posted on Feb 26, 2010
Wath kind of oil you need for the compressor kawasaki 840703 5 hp
Posted on Jan 04, 2010
Supply tub to tank
That is really not a hard part to find. You should be able to remove the broken one and take the whole tube into a hardware store and they can replace it for you. It should be a copper tubing with flare nuts on the ends. If not please post the model number of the compressor
Apr 27, 2013 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
I broke the air filter intake need to replace it where can i get one
I need to know the make and model of your air compressor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 17, 2011 | Air Tools & Compressors
Porter cable 3hp air compressor 130 psi no model number visible compressor runs builds up pressure and kicks off when the pressure is builded up in the tank// the compressor will not kick kick back on when...
Check to see if the switch will kick in if the pressure is released from the hose going to activate it...if so then the problem is the air being trapped between a check valve and the switch in the hose...
I think that is your problem...
There should be a way for the air pressure to change and represent the tank air pressure accurately....
The different compressors all have different ways of checking the air and then allowing it to release as the the tank pressure decreases..
There is a small hole there somewhere that is clogged with dirt and or oil...find that and clean it and you are in business again...
heatman101
Jul 27, 2011 | Porter Cable Air Tools & Compressors
I have a Central Pneumatic, 21 Gallon, 3HP air compressor. The compressor is exiting air through exthaust port.
If air leaks when motor is off, fault most likely in-tank check valve. Follow discharge air line from pump to tank. Brass/steel valve at tank is the check valve. Remove hose to valve and check for leak. Replace as needed. If air is leaking while motor is running fault could be reed valves in head. Faulty reed valves in head, or torn head gaskets will cause very hot discharge air and tank will most likely never fill to shut off (or take a very long time to fill)
Sep 06, 2010 | Air Tools & Compressors
Air compressor leaking air
you have a bad check valve ,the little brass valve is working normal
Apr 18, 2010 | Clarke Power Products AC2002A 2 Hp Air...
Oil type & owners manual
here is the oil you need. Manual is NLA. Eric http://www.kmart.com/shc/s/ProductDisplay?sid=KAx20061023x272xTier3&aff=Y&vName=Tools&CustomerMemberID=tfc_-_9_1_090811_cbdc17f8236de8319108ad3e858ffcf6&catalogId=10104&sName=Air%20Compressor%20Accessories&AirTools=&cName=AirCompressors&partNumber=9990000031945111P&storeId=10151
Aug 02, 2009 | Craftsman Air Tools & Compressors
AIR LEAK ON CRAFTSMAN AIR COMPRESSOR, 3HP,25 GAL, HORIZ TANK
The needle valve that you see is the unloader which releases air pressure from the discharge line after set pressure is obtained. If air continues to leak after the compressor shuts off, the check valve installed in the tank is leaking air out of the tank. Follow the air discharge line from the compressor to the tank. There you will find a brass valve which is the check valve. Simple test is to remove the smaller airline (1/4") from the brass valve and check for air leaking. If leaking remove brass valve and check for debris under the white seat. If you cannot clean the valve, replace with generic check valve from www.grainger.com. It will cost less than factory part. Just order the valve considering the fitting sizes that you need. For exact replacement,( www.sears.com parts). If you sears model # begins with WL then your compressor is made by campbell hausfeld and parts may be ordered from www.chpower.com. Good Luck with you repair and email if you have more questions.
Mar 21, 2009 | Craftsman Air Tools & Compressors
Wrench Support
An impact wrench also requires a few special accessories. An air-powered impact wrench runs off of an air compressor with a tank – the air compressor should have at least a 10 gallon tank and be able to generate at least 3hp. Also, an impact wrench requires special sockets that are designed to withstand the high torque applied by the wrench.
Aug 27, 2008 | Impact 3/4" Dr. Heavy - Duty Air Wrench
Air Tools & Compressors Logo
783 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
