Question about Memory Upgrades Computers & Internet
Manually remove virtual drive gamedrive - Memory Upgrades Computers & Internet
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
Sep 25, 2013 | HP Pavilion Computers & Internet
I have a cd I want to copy but it is copy write protected
A copy protected CD cannot get copied to an other.
Apr 16, 2012 | Audio Players & Recorders
How do i change the virtual drive setting?
I suggest to remove the program for virtual DVD and install it after if you need..or just open the program for virtual drives..and under options ..select to remove the drive ..it will be removed from the my computer folder too .
It will always be able to be enabled again ..
Dec 24, 2011 | Dell Computers & Internet
There isn't a paper jam there is ink in the cartridges, i have selected the printer. when it prints the paper comes out blank
Make sure that the computer has available hard drive space
Printing requires the computer to have a certain amount of available hard drive space to process print jobs and to send them to the printer. Step one: Check the virtual memory settings Virtual memory is the temporary disk space on the hard drive that processes print jobs. It usually requires at least 200 MB of disk space but might require more or less depending on the printer. Insufficient virtual memory might cause the issue. Follow these steps to check and modify the amount of the virtual memory available.
Click Start , right-click My Computer , and then click Properties . Click the Advanced tab. In the Performance section, click Settings . Click the Advanced tab. In the Virtual memory section, click Change . For correct configuration, the Initial size and Maximum size settings must be less than the Space available on the hard drive. If the Space available on the hard drive is less than 200 MB , skip to the next step. Follow the instructions to clear space on the hard drive, and then start these steps over. The Initial size setting is the amount of space reserved for virtual memory on the hard drive. The Initial size setting should be about 200 MB, and greater than or equal to the recommended paging file size shown in the lower section of the dialog box. The Maximum size setting can be any number greater than the Initial size setting, but it should be at least twice the Initial size setting. Change the settings as necessary to conform to the information in this step. Click Set , and then click OK . Try printing again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step
Step two: Run Disk Cleanup to remove temporary files Follow these steps to run Disk Cleanup. Click Start , click Programs , click Accessories , click System Tools , and then click Disk Cleanup . Disk Cleanup prompts you to select a drive to clean. Select the hard drive, and then click OK . Disk Cleanup analyzes the hard drive and presents a report. Select the following items from the report: Temporary Internet Files Downloaded Program Files Recycle Bin Temporary Files Click OK . If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step three: Remove unnecessary software programs Follow these steps to remove unnecessary software programs. Click Start , click Settings , click Control Panel , and then click Add/Remove Programs . Select a software program to remove, and then click Add/Remove . Repeat these steps for all software programs you want to remove. If you remove large software programs, run Scan Disk and Defrag on the hard disk drive. Look for these options in the System Tools section of Accessories
Mar 03, 2011 | HP PhotoSmart C4280 Laser Printer
CAN YOU PLEASE TELL ME HOW MUCH VIRTUAL MEMORY DOES A PATRIOT 2006 LAPTOP HAVE
Virtual memory?
Virtual memory is created and used by windows operating system.
This value can be changed and solely depends on the hard drive space available.
Simply put There isnt any limit, nor a minimum. The amount of virtual memory depends on how much was set up and can be increased or decreased at any time.
The purpose of virtual memory is to allow windows to use part of your hard drive as rams.
virtual memory and rams (conventional memory are different things)
you can have as much or as little as u need. increasing it improves performance.
So No one can actually answer that question. Simply put any amount you want is the correct answer!.
Mar 01, 2010 | Computers & Internet
After installing SP3 my Asus 900 C drive is full (3.7 GB), even though my data and most programs are on the D drive, which has 6 GB free. Can some of the Windows folders be moved across? John
Do not move Windows folders across to your D drive it will cause Windows to stop working.
You can change the Virtual memory from the C drive to the D drive, this will free up disk space on the C drive.
To change the Virtual memory follow these steps. : -
Click on Control Panel - System - Advance tab - Performance and click on Settings box - then Advance tab - in Virtual Memory click on Change box. Then change the Virtual Memory from the C drive (remove it) and set it up on the D drive. Use the same amount of memory or more but not less. You need to reboot for this change to take place.
Oct 06, 2009 | ASUS Eee PC 900 Notebook
How do I completely remove the WD Sync software so I can use my 500GB WD external hard drive for manual copy-and-paste
Assuming you are using XP, Vista, or 2000 you can format it as a NTFS drive. while a lt of folks do not like Vista, this is one area where it really shines.
Plug in your WD PASSPORT.
Bring up the START menu -> right click COMPUTER-> select MANAGE -> select STORAGE ->select DISK MANAGEMENT.
Find the dive -> select/highlight the WD PASSPORT -> right click and select FORMAT. make sure to format as an NTFS drive. Depending on the size of the drive this might take a while - so go have dinner and a movie.
Jul 01, 2009 | Western Digital WD Passport 250GB Portable...
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Microsoft lifecam issue
Partitioning software works with REAL Physical hard drives, not with virtual drives. Virtual drives are nonsense and should never be used to store data or images that one considers important. In this case, chances are your webcam selected some portion of your physical memory and called it a virtual hard drive, thus lessening both your computer's physical memory that could be used for other tasks and also making it impossible for you to retrieve your images or data from the virtual drive once the webcam was removed from its USB connection. Before removing the webcam from USB, you should have been advised to back-up your images to the REAL physical hard drive in whatever partitioning scheme you use on your hard drive, i.e. partition C:, D:, E:, etc.
Never but NEVER allow software to make important decisions for you, and Never use a virtual drive for transitory information that is easily corrupted but still considered important by you.
Your explanation was NOT to long, in fact it was the length of explanation that you gave that allowed me to fully address your issue
Jul 08, 2008 | Microsoft LifeCam VX-1000 Webcam
Psp
You could try
http://www.amazon.co.uk/GameDr-UMD-Cleaner-PSP/dp/B000BQQ2MI
If It is just dirty discs!
Apr 25, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
Top Memory Upgrades Computers & Internet Experts
David Payne
David Payne
Are you a Memory Upgrades Computer and Internet Expert? Answer questions, earn points and help others
