Question about Ouellet OASU10000T Electric Wall Mounted Panel Heater
Builtin. Thermostat won't work. On wall heater
Will work some times, won't stay on very long
Do temco wall heater have a flame sensor
It more than likely has a bad thermocouple, it is the flame sensor. Some times if you move it a little bit closer to the pilot flame it will work. Also make sure there is no carbon or soot buildup .
Nov 15, 2014 | Heating & Cooling
Williams wall furnace m#5009622, pilot light stays lit but main burner will not ignite
Check your thermostat most times all u need to do is tweak with the lever or on/off switch.
Nov 18, 2012 | Williams (5009622) Ceramic Gas Wall...
I want to buy form Costco a Sylvania Convector 2000 watts with built-in thermostat. I already have a wall electronic programmable thermostat.can I install this convector anyway and not plug the built-in...
No, you will only be able to use the heater's Thermostat.The programmable wall thermostat you already have is either an 18 volt or 24 volt thermostat. It won't work with a portable electric heater.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Heating & Cooling
New wall heater installed but after a couple of minutes it turns off by itself but thermostat says on.
The problem may lie in where the wall thermostat is placed. If it's too close to the heater, the heater is shutting off prematurely. However, I'm assuming the plot stays lit after the burner turns off.
The Thermostat should not be in the path of a warm air discharge from the furnace, a lamp, TV set, etc.
If the installer did not leave you the Owners Manual, here's a link to it, in a pdf format that you can print and have for future reference. http://www.wfc-fc.com/pdf/Monterey_Top_Vent_IOM.pdf
Please let me know how it worked out for you.
Rich
Feb 16, 2011 | Williams (5009622) Ceramic Gas Wall...
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
When turning thermostat on flame want inite ploit light just stays on
i replaced the main board and the furnece worked good.
5 days and its out agin please help.
Oct 12, 2009 | Coleman Propane Forced Air Heater...
Ouellet OASU10000T Electric Wall Mounted Panel Heater Logo
Top Ouellet Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an Ouellet Heating and Cooling Expert? Answer questions, earn points and help others
