Question about Cell Phones
The KX TDA30 problem is that it powers off sometimes several times a day. The red alarm light does not come on. If we up plug the power,then plug it back in again, or turn the power switch off and then on again, it will reprogram itself and then work for a while.
  • 1 more comment
  • donevans739 Jun 19, 2009
    Once we unplug and plug it back it, everything seems to work fine and sometimes for several days, then (like today) it has gone off 3 or 4 times. Thanks
    Thanks very much. I remember programming it when it first came,--is this something I can do again, or is this something that has to be done elsewhere?
    Thanks for a prompt and understandable reply
  • 6,784 Answers
HI, this is the direct result of core programming failure. the core program in corrupt and, the entire main board should be reset and re coded. the power cycle will be affected as well.
This unit will need to be sent back to the manufacture for this repair. You may be able to receive core service at your local providers sales terminal. i would contact the nearest retailer for repair details if possible.
Posted on Jun 19, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters Jun 19, 2009
    Yes, this issue will progress. the remaining program is functioning at this point because of the reboot you are initiating. this reboot will not work soon because, the core program will eventually become completely corrupt., in return, rendering the phone useless. it will need to be reprogrammed soon.
    The corruption will reach a level to the point that , the reboot will not be able to initialize itself. if you allow this fault to totally corrupt the core programming, it will destroy the main board. this will require a total board transplant. this will be an expensive repair. the reprogramming is a bit cheaper. its best to get this serviced while the board is still operational.
  • Michael Masters
    We recommend using the service tech route when dealing with this type of electrical issue. the control unit is housed within the control panel and, there are many wires that are joined by a harness that will need to be replaced correctly.
    It will require some moderate dismantling of the panel as well during extraction. this can be a tough and challenging job for a non experienced do it yourselfer.
  • Michael Masters
    I apologize for the confusion. that response was directed to another issue that is on my board. please disregard the above post.
    Concerning your phone and core fault. this issue is best handled by the manufacture. the core programming will need to be re coded and, loaded on the main board by the manufacture or , local repair depot.
    Since, this was due to massive corruption, the main board will need to be wiped and, re coded.
NEED TO INSTALL kx-tda MAINTENANCE CONSOLE SOFTWARE ON pc
3.3 Installation of the KX-TDA Maintenance Console
absi.net/pana/HLP/data/79.htm
If you do not have a backup system data, you have to set the PBX to the factory ... Toinstall or uninstall the software into Windows 2000 Professional or Windows XP ... Save the setup file of the KX-TDA Maintenance Console on your PC. b.
[PDF]KX-TDA30/KX-TDA100 Model KX-TDA200/KX-TDA600 PC ...
ict3.com/Data/KX-TDA600/PC_Programming_Manual.pdf
... manual for future use. KX-TDA30: PSMPR Software File Version 3.0000 or later ... Section 2, KX-TDA Maintenance Console Operating Instructions. Serves as ...
[PDF]KX-TDA30 Getting Started - Telephone Engineer
Dec 03, 2015 | Lands Phones
How to disconnect the alarm system .
just cut the red wire and isolate him
Nov 20, 2014 | 1994 Mazda 929
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I have just re-installed my pdp5071 after it being in storage for a few years.. the unit will not power up . at plug-in several clicks at upper left rear of unit ( click - stand by red light on-off, pause...
There are two power buttons on this TV. One on the lower left front and one on the right side. make sure they are both on. During storage it may have deactivated both of them.
Apr 18, 2011 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Buzzing alarm sound before ignition
The yellow or red light would mean a control board that is bad or going bad. The buzzing sound could just be the transformer not uncommon to hear a buzzing sound from the transformer.
Dec 16, 2009 | Heating & Cooling
Freezer alarm and signal light comes on daily
The beeping and light indicates the need for a new battery (9v)
May 22, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Cell Phones Logo
48 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
