Question about Vehicle Parts & Accessories
Cars globes keep blowing
I have replaced the one headlight globe on my car several times in the last 2 months , and it lasts 2 or 3 days and then it needs replacing .The indicator globe on that side is also giving problems
  • 53 Answers
It may be that the alternator is over charging
If the head lights flare up when you rev. the motor it's a sign this is the case. Have it checked by an Auto Electrician.
Posted on Apr 18, 2014
Why do I keep blowing. Head lightbulbs
1 # Bad Earths in wiring harness
2 # Vibration in headlight housing
3 # Running higher wattage globes
4 # Touching the glass of the globe with bare hands while fitting
May 03, 2015 | Motorcycles
How do i replace headlight globes on mr2 sw20?
Turn headlights to on. Then 2 clicks back to turns lighs off but keep headlights up/open.
Remove headlight shrouds, (Black plastics.) Use phillips + head screw driver.
Remove chrome trim ring using phillips head screw driver.
Pull out headlight bulb. Disconnect from harness.
Reverse to install.
Sep 12, 2014 | 1991 Toyota MR2
Replace park bulb.vt commodore
To replace the front parklight globe on a vt commodore can be a little tricky.
1.turn the lights on to see which 1 is inoperative once you know turn lights off.
2.open bonnet
3.go to side that is inoperative and on the back of the headlight you will see a round large plastic cover turn this to release it.
4.under the headlight globe there will be 2 wires flow these to the park globe socket gently twist and pull it out.
5.once the sockets out and you can see the globe ,pull the globe out of socket.
6.push new globe into socket
7.refit the socket in headlight
8.refit all trims
9.turn lights on make sure new globe is work..
Jan 22, 2014 | Cars & Trucks
Low beam headlights blowing only 1 at a time both sides 5 x
check for loose globes and loose connections at the pins of the globes as arcing causes light failures.
Jan 02, 2014 | Cars & Trucks
Tail light 2012 html fuse
check for loose globe fittings and bad earth connections . Blowing the same light is indicative of a loose globe in the housing and shorting causing power surges which burn out the filament in the globe.
Oct 30, 2013 | 2011 Nissan Qashqai 1.5
Headlight keeps blowing out 1996 yamaha virago 1100
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight globes keep blowing
Yamaha Virago XV535 1100 1981 1994 Service Manual
OEM parts for Yamaha
Yamaha Virago XV1100K Owner Manual
Jul 22, 2012 | Yamaha Motorcycles
02 Focus Wagon - Rear tail light/brake light keeps blowing bulbs. Bulb is white when removed, replacement bulb last about a week, then blows again. Any idea what the problem may be.
If a bulb blows white the gas mix in the globe is incorrect and you probably got hold of a bad batch of globes from your supplier. Try buying your bulbs from another source and see if that works out better.
Mar 21, 2011 | 2002 Ford SVT Focus
1997 Ford Light Duty F-250 Problem: Passenger rear brake light / signal light Brake light is intermittent. Signal works most of the time. Emer. flasher is intermittent. Center & left side work fine....
It appears that you may have an intermittent earth connection between the globe sockets and the vehicle body.
First, check how well the metal base of the globe fits into the socket. If it is a bit loose remove the globe, squeeze the sides of the metal socket with some pliers so that the globe fits snugly in the socket. If it is still not working correctly, check the earth wire that runs from the globe socket and any connectors in the wiring loom near the Light Assembly as well as where the earth wire is attached to the body. Remove, clean and re-attach securely if necessary.
Sep 14, 2010 | Ford F-250 Cars & Trucks
Passanger headlight
Did you touch the glass on the globe before fitting it?
Jul 12, 2008 | 2001 BMW 330
89 Pulsar Headlight
you need to replace it from the back, if its not accessable try removing afew things if not remove the entire headlight as it must be fitted from the back.
May 23, 2008 | 1989 Nissan Pulsar
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
