Question about Garden
Hi, my masport 4 stroke mower started normally but stopped later when the fuel was running out as there were a lot to mow . I refilled the tank to about one third of its capacity. When I pulled the starter cord to restart it, I found that the cord was locked after pulled out for just 15cm. The engine was still hot. I waited for about 5 minutes and tried again, and the cord was still locked. What happened?
3 Suggested Answers
  • 5 Answers
SOURCE: Continuously stalling and extreme difficulty restarting.
The brass "Bolt" that holds the "cup" on the bottom of your carburetor is also the main fuel metering jet for the engine. Get yourself a can of automotive carb cleaner, the aerosol type that comes with the small red plastic tube on the side of the can. Remove the "Bolt" and "cup". (Tip: tilt the carb side of the mower UP about 45 degrees and support it with whatever you have, wood, bricks etc. This will help stem the flow of gas from the tank while you have the "cup" removed.) Examine the "Bolt" and you will see one or two small holes in the side of the "Bolt" between the hex head and the threads. These are the metering orifices. Use the carb cleaner to throughly clean the "Bolt" orifices. (Tip: DO NOT attempt to 'drill' the orifices clean) Next, use the red plastic tube to spray carb cleaner up through the hole on the carburetor that the "Bolt" screws into. Be liberal with the cleaner. Finally, clean the "cup" with the spray one more time for good measure. Put everything back together. (Tip: easy does it on tightining the "Bolt") Level the mower, check for leaks and verify the oil level is OK. If the plug and air filter are up to snuff you should be good to go. (Tip: how old is your fuel? You should keep it around for only about 30 days unless you use fuel stabilizer. These little engines LOVE fresh fuel) Good Luck.
Posted on Jun 27, 2009
  • 173 Answers
SOURCE: Hi, my masport 4 stroke
Make sure the shutoff brake is not dragging.that is the part that is down by the flywheel when you let go of the handle the motor might need a new cable if it is not releasing all the way.this would cause the pull cord to be hard to pull and hard to start.
Posted on Dec 28, 2010
Lawn mower not running well
Try changing the fuel and air filters. Also drain the fuel tank and refill with fresh fuel.
Feb 23, 2015 | Briggs & Stratton Garden
Why wont my John Deere D130 will not stay running
You know the old adage, Keep it simple, lol.
I was mowing along on my LA145, which had about 200 hours on it, and it slowed down then died. Before it died, it was acting like it was losing power. It felt like it was only firing on one cylinder. I waited a bit and it restarted after a lot of cranking. I made a couple mowing passes, and then the same thing happened.
Because I have mowed commercially for many years, I know my equipment inside and out. This mower was in top running condition and should not have been acting this way. There were no engine misses, no backfires and it was not normally hard to start. I knew the carburetor was clean, the coils were good, and the plugs were new. The fuel filter was recently changed. I got off, lifted the hood and gave a general inspection of the engine compartment. I noticed the fuel filter was nearly empty. I pulled the hose off the tank side of the filter and saw there was no flow.
The gas should gravity flow from the tank to the filter, if the tank has a good supply of fuel. Not that I recommend this practice, but I have no problem with doing it myself....I wiped the hose off and blew air back into the fuel tank. It helps to take the gas tank lid off first. After I got a good flow of air going back into the tank (it required several lungs full of air, you can hear the bubbles) the fuel began to gravity flow back through the hose at a decent clip. This fixed the problem. There is likely silt build up in the tank and it settles at the output port blocking the flow of fuel.
The problem repeated itself several times last summer. Back at the shop, I used compressed air to blow the line clear. The problem has not shown up in quite some time.
Aug 29, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
I have a brand new masport mower, too much oil was put in and it was blowing white smoke, dripped it up drained some out few days later start to mow it'll mow for a few mins the blow alot of white...
make sure oil is at the correct level , remove exhaust muffler drain all oil if any, reinstall and run it until smoke clears , it should not take too long . Make sure engine is cool when working on any component
Feb 25, 2013 | Garden
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 | Garden
Masport 400 rotocut, four stroke B & S motor. Won't start now after previously giving no trouble. But when you tip in on its side and then righten it it will start for a few moments.
Water in fuel water settles to the bottom of thre tank blocking the pickup tube empty tank dry it out with a paper towel and refill tank
Mar 28, 2011 | Garden
I had this problem with my John Deere- After replacing the Inline fuel filter to no avail, I later found out that there is an additional filter inside the gas tank to trap grass particles that may drop in the tank where you fill it. This may or may not help, but I hope it does.
Jan 05, 2011 | Garden
Hi, my masport 4 stroke mower is very difficult to start, ie the cord is very hard to pull. cheers
Dec 28, 2010 | Garden
Mower wont start
About the only suspect is water in the fuel - even after you drained it. If your Masport has a 'Quantum' style engine with a float type carb, undo the bowl nut and allow the float chamber to drain. Odds on there's water in it. A single drop will block the jet. If it's a 'carb-on-the-tank' engine, chech for water droplets in the bottom of the tank. They wll be obvious if present.
Mar 11, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
