Question about Magic Chef Ovens
Amp draw my brand new oven glow bar igniter is only drawing 2.5 Amps, but after about 20 seconds, the gas comes on the oven lites shortly after the safety valve opens, in like 1-2 seconds. The glow bar continues to glow bright after burner is lit. While burner is going, igniter Volts stay at 115-116V and Amps stay at 2.5 Amps. The new igniter came with data sheet that says it should range between 3.3-3.6 Amps on the instructions that came with it. Should igniter glow/get power while the burner is going? It stops glowing after the burner turns off in it's cycling. I don't want to burn out my new igniter, like the first one. I'm wondering: could low amperage damage the igniter enough to eventually put a white crack through it and stop working, like the first replacement igniter. I am on my second try after what is thought to be "defective" igniter. I may have handled it too roughly, and I know for sure that I touched the glowbar element that broke, trying to make sure there were no cracks, and later finding out this was a BIG NO NO and could be the reason why the new igniter burned out. Could there be a problem with the "timer" which, I think, is the name of the small plastic box shaped thing that the igniter hooks up to?
    Prodigy:
    An expert who has answered 500 questions.
  • Magic Chef Expert
  • 650 Answers
Sounds like it is working as designed. Igniters should last fro several years but can crack at any time.
Posted on May 25, 2014
3 Suggested Answers
  • 1218 Answers
SOURCE: oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
Posted on May 09, 2009
localwonder
  • 6784 Answers
SOURCE: glow bar comes on but oven ignites 20-30 minutes later
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working. If the ignitor did not appear to function and it is the spark type, it may be out of adjustment which generally requires professional service or it may require replacement. If the ignitor is the glow type, you can test it for resistance with a multimeter.
The ignitor has two wires connected to it.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading anywhere between 50 and 600 ohms. If you get a reading of zero or infinity, the ignitor is definitely bad and will need to be replaced.
(((If the ignitor is optimal, this will confirm a faulty set of coils. replace them all if this is the case))).
Posted on Jul 28, 2009
Oven will ignite but want rare up
Depending on what model stove you have on what it uses for ignition.
Most likely a glow bar type .
even though it glows it still can be bad.
glow type needs to draw the right amps for the safety valve to open if not the right amp draw valve will not open.
that's why its called a safety Valve no glow no lite.
Change the glow ignition other then that send us the model # off your range and we can get you exact price quote on parts you need
Have a great day
Ken R.A.P.
Mar 10, 2015 | Ovens
Tip
What the problem is when your gas oven ignitor glows,but no heat for the oven
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
on Jul 31, 2011 | Ovens
Gas oven will not lite but thing in bottom glows do not smell gas
By "thing in bottom" Iam assuming your talking about the igniter. If you are and it is only glowing then it probably needs to be replaced. If you cant smell the gas either thats a worring sign in of itself. I would first replace the igniter and then go from there though. Let me know how it goes!!
Aug 09, 2011 | Amana Ovens
I have a Maytag Performa gas stove, the burners work fine, but the oven wont come on at all, the ignitors glow, but it doesn't seem to be getting any gas??
just because the ignitor is glowing doesn't mean it still isn't bad.you need an amp meter with a clamp on it,stick one of the wires into the clamp,if it's a flat ignitor it should read 3.2 amps,if it's round i believe it's 2.5 amps.if it doesn't get the correct amps it won't let the gas into the burner tube.you say the ignitors glow,do you mean the broil doesn't work also?if so you could have a bad gas valve or the clock could be bad,there's a computer board in the clock assy.on some of the machines.next time send the model number,open the bottom draw and you should see a tag with the model and serial number on the frame that the draw covers when it's closed.check this site out it should help you...... Appliance Repair Revelation: Troubleshooting a Gas Oven That Won't Fire Up ' Oven Repair ' Fixitnow.com Samurai Appliance Repa
Mar 23, 2011 | Ovens
Oven does not ignite broiler does ignite burners do ignite
the ignitor should pull 2.8 amps or more. it can lite but not release gas. just beacuse it is glowing doesnt mean its good. check amp draw w/ meter if less than 2.8 amps. change it out. if doesnt glow or draw any amps. check to be sure have 120v. then change ignitor.
Aug 04, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Jan 14, 2010 | Ovens
Electric ignition element heats, but gas does not come out/ignite. The broiler on top side works fine.
even though the ignitor is coming on it is probably too weak to open the gas valve. with an amp probe you should read 3 amps and above. anything under 3 amps you should replace the ignitor. hope this helps
Aug 21, 2009 | Ovens
VDGO viking gas oven upper won't heat
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Ovens
Tappan #tgf605wfw5: igniter gets hot but gas valve does not open up. Part of the igniter bad, or the valve bad. How to check to see which one is bad?
Ovens Logo
67 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
