Question about GE JBP66 Electric Kitchen Range
Fisher and paykel prema oven does not heat on all modes
Does not heat on fan forced mode , works on other modes
5 Suggested Answers
watugot
  • 290 Answers
SOURCE: Oven does not heat up
It could be a bake element or an oven control problem. If you have a volt meter, remove the back of the oven and test the voltage across the bake element terminals while it is on. You should have 240 volts. If it is less than that, you have a control problem.
If you have no way to check the voltage, replace the element and try it. It is the cheaper part to replace if you want to try something.
Post back if you need to know how to change it or need further guidence.
Posted on Oct 19, 2007
SOURCE: Oven won't heat, only in broiler mode
change the oven ignitor.
Posted on Dec 06, 2008
heatman101
  • 43501 Answers
SOURCE: My wife cleaned the oven yesterday in the self
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on May 14, 2010
heatman101
  • 43501 Answers
SOURCE: Stuck in clean mode. Ge Spectra xl44 My wife
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Nov 27, 2010
Fisher and Paykel oven hot heating on fan force
Possibly a burnt out fan element. You or a service person needs to test the element & wiring with a multimeter.
May 10, 2016 | Fisher and Paykel Ovens
Fisher & paykel b1602cte oven fan in element at back of oven not working
FIRST YOU NEED TO KNOW JUST HOW THE FAN WORKS, DOES IT WORK OFF OF ELECTRICITY OR IS THERE A COMPUTER CHIP IT WORKS OFF OF. DOSE IT WORK OFF OF JUST A SWITCH. LOOK UP ON LINE TO FIND A MANUAL FOR A FISSER & PAYKEL B1602CTE IT MAY TELL YOU WHY IT IS NOT WORKING.
Jan 29, 2015 | Fisher Ovens
The lower oven of my Fisher Paykel B1603ED dual oven is oven is overheating. I carefully replaced the Thermostat with a new and it did not fix the problem. Also when it is set to fan forced it will no
The model number supplied cannot be found on the web site a parts manual can be obtained to provide information on your product.
goto fisherpaykel.com and find the manuals available parts would be best and they may use several ways of regulating the supply . Or an element has blown visual check when cooker is ISOLATED FROM THE MAINS SUPPLY. There usually is a Grey colour round the hole in an heating element, if not sometime a black ring as if too much heat in one spot, test with a continuity tester it should have conduction.
Hope this is helpful
Regards
John
Nov 01, 2014 | Ovens
I have a fisher & paykel Astro built in wall oven which has a problem, after using the oven and then turning both switches off for some reason the rear element continues to stay on and will not switch...
Hi - theres a few components that may well cause this to happen - the power module which controls the heating & fans etc - isolating relay which switches the heater & fan relays - it only avctivates when a cook mode/cycle is selected.
One of the two components could be faulty - I guess a sparkie or techie may be your best option..
Aug 07, 2011 | Fisher and Paykel AeroTech OS302 Electric...
Hi.. I have a wall oven fisher & paykel model 600e and after my girlfriend tried to use it pressing all the buttons without knowing what she was doing the element is not heating up anymore :( what...
The electronic timer must be in manual mode for the oven to work. Turn the oven on. Play around with the clock/timer buttons using as many combinations as you can. When the oven indicator light comes on the clock/timer is in manual mode. This could take 5 minutes or more. Be patient.
Mar 01, 2011 | Ovens
I have a Fisher & Paykel OS302. The temperature and oven mode selects are dead, no LED display, no operation. The clock module is working. This happened all at once, I tried to turn it on and both...
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
Feb 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
Not heating in fan forced mode
Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
GE JBP66 Electric Kitchen Range Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
