Question about FUJIFILM FinePix AV100 Digital Camera
Card error when i swith on the camera but there is no card in the camera in the display card erroe
My memory card is showing no images and card error
For how long have you been with this memory card? Memory cards have a life span and yours might have done that.
Nov 19, 2011 | Samsung BL103 Digital Camera
Getting lens error, when ever am swith on the camera it is showing lense erros and also traying to open the lense and cloding the cam
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 22, 2011 | Nikon COOLPIX L3 Digital Camera
My Sony Cybershot DSCHX5V Digital Camera shows a message on the display that says system error when swithed on. I have an sd hc 16gb memory card in the camera. Just before this problem happened it said...
At first, you have to find out the manual of your camera to see that if your camera can support a 16GB memory card. Not all the cameras can use a large memory card, as there is some limited maybe have been written in the camera manual.
Jan 17, 2011 | Sony Cybershot DSCHX5V Digital Camera
When I turn on the camera following erroe message is displaying: Write protect. How to remove this error?
You didn't specify the make and model of the camera, so I'll assume it uses SD cards.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 16, 2010 | Cameras
Image Management File Error
everytime i turn it on an error appeared ''Image Management File Erro '' :(
Dec 09, 2009 | Sony Cyber-shot DSC-T77 Digital Camera
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
Mar 09, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
Lens error No. 221,0,0,0
I have Pentex Optio E 30 camera
When i start my camera , i get error message Lens Error : 221,0,0,0
lens got stuck and it is not coming out for zooming
Sep 06, 2007 | Kodak EasyShare C703 Digital Camera
Format Error in Sony DSC-650
Please try with new memory stick. If it does not help please claim for an in warranty repair. If you need more info please advice.
Apr 12, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
FUJIFILM FinePix AV100 Digital Camera Logo
13 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
