Question about Cuisipro Foam Pump
Stopped working PUMP NO LONGER PUMPS LIQUID
While refilling, you may have inadvertently lost the very tiny white plastic bead that sits loose inside the pump assembly at the bottom of the spring piece. Same thing happened to both my units. So I used a round pinhead from a decorative hatpin. Just pulled it loose from the pin and dropped it into the bottom of pump shaft and all worked again. The bead prevents the pump from pushing air back into the soap reservoir instead of out the dispensing tip.
Posted on May 22, 2015
How to fix double starts from points kicking the breaker
If the breaker is tripping you need an electrician to check wiring, pressure switch shouldn't be a problem. Don't try to work your way around electrical, always remember the unit will last longer if electrical is running properly to unit.
Aug 31, 2014 | Goulds Pumps Goulds RGS2012PA -...
How does a compressor work?
it pumps vapour into a small tube that is cooled and turns into a liquid. The liquid boils off in the evaporator and the compressor sucks it back out and starts again. It's just a high powered pump.
Jul 14, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why doesn't my front windshield washer not work?
sounds like you have been using that blue liquid antifreeze stuff ,this is lethal to the rubber seal inside the pump and its swolen up ,you will need to strip the pump and rub the rubber seals down with a file and then it work these double throw washer pumps are expensive i think for what they are
Apr 27, 2014 | 2009 Saturn VUE
Coffee makers
Generally, coffee makers DO NOT have a separate "pump" that pumps any water of coffee around, but depends on a heating mechanism, that when the liquid is BOILING, causes pressure that forces the liquid to move to another location. If the heating coil is NOT working and getting the water/coffee hot enough to boil, then it will have to be replaced.
Feb 22, 2014 | Krups Nescafe Dolce Gusto
1994 ford ranger 2.3 fuel pump has burned out after 2 weeks, Why?
how full do you keep the tank..electric pumps will cavitate when the tank is less than 1/4 full..they use the liquid tokeep cool..also have you put on a new filter? if not do so.. theclogged filter will make the pump work harder..
Jan 15, 2014 | Ford Cars & Trucks
Pump growls when oil is alil wet!!
I do know a bit about pumps, not specifically THIS one but in general.
Usually pumps will start making that kind of noise when it is working too hard (the mixture is too thick) which causes the pump impellers to spin too fast with insufficient movement so it beats the air molecules out of the water/liquid , or you have a seal leaking into a bearing.
Mar 28, 2013 | Fish
Pump works for about 20 seconds then stops for 40 seconds then starts again.
this sounds as if motor is overheating and the thermal switch is stopping it (why it restarts by itself) if a pump is overheating then a few reasons need be looked at , is pump encountering higher viscosity's than designed for and is having trouble moving liquid fast enough , is distance pump has to lift liquid over what it's designed to do most of these pumps use liquid it's moving to provide cooling to pump , is liquid it's moving warm/Hot allready if so use different type of pump (non submerged) and last but not least is pump worn out and is failing moving parts wearing together make heat !!! ?
Jun 27, 2010 | Little Giant Submersible Fountain Pump
Anyone know where to get a new pump?
I give you the newegg of liquid cooling.
http://www.frozencpu.com/cat/l1/g30/Liquid_Cooling.html
I am not sure if the pump in a XT can be replaced. They sell pumps sperately and I certainly do think real men have their liquid cooling internal. Considering the XT was made so that you dont have to mess with radiators and pumps I doubt you can replace the pump. Looking at the XT pump its weak at 300 liters a hour.
I recommend danger den, swiftech and OCZ. It looks like the XT uses 3/8 inch so thats what these pumps are.
http://www.frozencpu.com/cat/l3/g30/c107/s154/gallery/p1/Liquid_Cooling-PC_Water_Cooling_Pumps-38_Water_Pumps-Page1.html
Jan 31, 2010 | Zalman Tech Reserator XT Black Water...
The pump on my system stopped working for a few days and now the water is really green. Would the pump clear the water back up when its running again or do I need to add something to the water to help it....
Get the pump going and add 3 jugs of liquid chorline and let the pump run overnight. The next day clean the filter and add 2 more jugs. This will get you into shape until you can test the water and get exact needs from your local pool supply store.
Jun 24, 2009 | Intex Automatic Salt Water System for ...
Cuisipro Foam Pump Logo
203 people viewed this question
Top Cuisipro Dishwashers Experts
Owen Barnes
Are you a Cuisipro Dishwasher Expert? Answer questions, earn points and help others
