Question about HP Officejet 4110 All-In-One InkJet Printer
How do you receive fax on hp officejet 4110
Please help
  • HP Master
  • 1,165 Answers
Do you have any Digital Answering Machines in the house?
or is it a dedicated line?
anyway heres the link for the 3 digit error codes document, its a public document that can be found by searching www.hp.com using this Article #: bpu02549 or buu02549
anyway as you can see 388 result/solution is the following...
Problem: Unable to complete the connection.
Solution: *Reattempt the fax reception at a different time when telephone line conditions have improved.
Now this means that one or both fax machines can have a problem. So lets isolate the problem.
Place a regular phone into the wall jack that the OJ 4110, if there is a static sound then its the phone line that is having the problem. if there is no static continue on...*Note if you have a DSL Internet service you NEED a filter for the fax*
What this is most commonly caused by is Bad line conditions which can occur in some different ways.
1) If there has been recently a Thunder Storm the electrostatic discharges interupt phone signals.
2) Recent power line downage
3) Recent Phone line downage
4) The phone company upgrading the lines
But basically something is BLOCKING the faxes from hearing each other. That is why you get this error code.
You can call your phone company to run a line trace. The reason you want to do this is so that you can eliminate the possibly of Static, Yes there are differnt types of it;
1) the normal static that you and me can hear
2) the SuperSonic Static, AKA Static in the Higher Frequency Ranges, where your DSL internet connection is. the Fax will pick up on those Higher frequency ranges, and it will cause problems. So put a DSL Filter on the Fax it wont hurt, and most of the times it helps alot.
Again Make sure ECM is disabled.
other than that, try unplugging all devices on the phone system an try...
i think there is alot fo information, i cant think of anything else...
Hope that helps
Posted on Jun 19, 2009
Solution No 1 is right on, the other problems I had to work around was connecting the answering maching into (4110) "Connector 2 and making sure "NOT to use the cord that came with the 4110" for that. Using the appropriate cord that came with the 4110 for "Connector 1" to the appropriate DSL filter, then the filter into the wall jack. This work around did allow me to both send and receive faxes with my 4110, along with the suggestions in Solution No 1.
Posted on Aug 24, 2009
2 Suggested Answers
prashanthcl
  • 460 Answers
SOURCE: The fax in my HP Officejet 4110 all-in-one is not working.
you have not installed the printer at your PC.pls installed the printer.
Posted on Sep 30, 2009
Installed hp officejet 4110 but cant fax
We can able to send the faxes with out PC.Driver support required when we chooses PC faxing only. Driver CD or down loaded full feature drivers required to install, Browse below link,select OS down load full feature drivers, install....http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90792&lc=en&cc=us&dlc=en&lang=en&cc=us
Jan 01, 2012 | HP Officejet 4110 All-In-One InkJet...
How do i check that HP officejet 4110 all in one printer software is installed in my computer.
Go to Printers and Faxes and right click on the HP OfficeJet 4110 printer,click on Properties then click on Print Test Page. If the Test pageprints correctly then the printer driver is installed correctly.
If the printer is not displayed in Printers ans Faxes or the Print Test Page does not work then install the printer driver.
If you do not have the printer installation CD then -
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Aug 15, 2011 | HP Officejet 4110 All-In-One InkJet...
Di i put paper to be copied for faxing in face up
Hi there
On most fax sending I know is always face down but being not sure of all printers I but a manual for you to have, if not sure send a fax to some one you know one way and then the other way, and just ask them each time after sending did it work.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/HP-Officejet-4110-Manual.pdf
You will need an adobe reader to see this file if you not got a Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 13, 2010 | HP Officejet 4110 All-In-One InkJet...
Sep 30, 2009 | HP Officejet 4110 All-In-One InkJet...
All-in-one 4110 hp fax not working
what kind of connection you are using, I ment broadband or some other
Aug 21, 2009 | HP Officejet 4110 All-In-One InkJet...
HP officejet 4100 series all-in-one Scanner not working
tengo problemas de compactibilidad ente los istaladores de la hp 4110 all-line one con windows vista que hago
Feb 18, 2009 | HP Officejet 4110 All-In-One InkJet...
Regarding hp office jet 4110 printer driver
get it here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90792&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20â»
there are three models
HP Officejet 4110 All-in-One Printer
» HP Officejet 4110v All-in-One Printer
» HP Officejet 4110xi All-in-One Printer
do check which is yours and download...hope it helps!
Nov 20, 2008 | HP Officejet 4110 All-In-One InkJet...
Do not receive fax
I don't have the flyer with me and I need to use my scanner. How does it function?
Aug 02, 2008 | HP Officejet 4110 All-In-One InkJet...
Hp officejet 4110 all in one
I have the same experienced the same problem. When trying to copy I go through an endless loop of copy options without the ability to actually start the copying process.
Jun 17, 2008 | HP Officejet 4110 All-In-One InkJet...
HP Officejet 4110 All-In-One InkJet Printer Logo
259 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
