Question about Canon Office Equipment & Supplies
A problem prevented the document from being scanned. Please try again, or for troubleshooting information, see Help and Support or the information that came with the scanner.
IB4G2008
  • 3587 Answers
SOURCE: Scanner troubleshooting
most likely it's the printer drivers.
go here to get fresh ones, but you may wish to remove old version first.
Posted on May 10, 2008
clark_styx
  • 282 Answers
SOURCE: scanner problem again -- HELP! junk 'solution' given
try to install and run scan diagnostic utility found here ftp://ftp.hp.com/pub/softlib/software8/COL17048/oj-45265-1/ScanDiagnosticUtility_ver_1.5.exe
Posted on Jun 24, 2008
  • 14 Answers
SOURCE: Kodak DS3500 scanner
Are you using a Kofax SCSI card or an normal SCSI controller like Adaptec?
By using a normal SCSI controller, is there an ASPI driver problem after a WIN XP update? After an update check the ASPI dlls in \sytem32. They should be version 4.71 or higher.
Check the SCSI connector pins and the terminator.
If available change the cable.
Scanner check:
Is the green lamp (Ready) on or is the red lamp (Error) on?
- green lamp on:
the internal self test is ok, but the internal SCSI interface may possibly faulty.
- red lamp on:
the internal selftest detect an error.
It's possible that the DC/DC power board, the CPU board or the power supply inside the scanner is defective.
After reassembling the front side camera you will see at the bottom a PCA board with some LEDs whitch indicate by red light the different voltages when power is on. You find the different voltages printed at the PCA close to the LEDs.
In case on or more LEDs don't shine the according DC/DC transformer on the PCA is defective.
Futher you see LEDs at the camera PCAs. They should be on too.
In case the CPU board has an defect you must have an special Kodak activation tool to unlock an new or used CPU board after exchange.
Posted on Jul 18, 2008
acdr
  • 1913 Answers
SOURCE: HP Laser jet 3330 scanner problem unable to communicate
http://www.printcountry.com/drivers/HP_DRIVERS.asp
also try this
http://www.soft32.com/s/Windows/Drivers/Printers/3-377-0-5.html
Posted on Nov 04, 2008
SOURCE: computer says there is no document on scanner
Had same problem with mac os 10.4 solution was downloading the latest epson driver from epson it still didn't work. turned out that the "epson perfection 1670.ds " old file was in the trash and the scanner was still using it. I turned off the scanner, rebooted the mac and "empty trash". Turned scanner back on and it worked. If you still have the problem make sure that you only have on "epson perfection 1670.ds" file in your HD,library,image capture,twain data sources.
Posted on Feb 11, 2009
My scanner and copier are giving me all black documents. HELP PLEASE.
is it possible the color cartridge is empty? also when you print a document try it this way... press and hold the Crtl button and press "P". so it's "control P" now at the bottom of the left side menu screen you will see a "color" button select Color and then print.
Jan 06, 2015 | Lexmark X6570 All-in-one Inkjet Printer
I have officejet 6500 and it will not scan. Upon pressing scan button, it tells me "no scan options" and that I should refer to device documentation to troubleshoot. I do not know what that means...how...
I have a solution for this issue. However to provide the appropriate steps, please get back to us with the following information:
* How is the unit connected to the computer? (USB or Wireless)
* What is the operating system of the computer?
Please get back to me with the requested information
Apr 03, 2010 | HP Officejet 6500 Wireless All-in-One...
Kodak ESP9 all-in-one printer. unable to scan to doument
how do you scan your document are you using the buttons on the printer or are you using the computer and the home center software?
If your using the printer buttons I strongly suggest use the computer and its software the home center. Now if still not scanning and it takes time to scan. restart the computer and while the computer is restarting unplug the power cable of the printer., then do again the scanning if yur computer is ready.
If the troubleshooting did not solve it means the software or the home center is having a problem call kodak for assistance for the software toll free 1 800 421 6699., GudlucK
Nov 01, 2009 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
HO OFFICEJET ALL IN ONE 5610
hello..
yes you are using the right catrtriges, try to click this link below. there are are the steps in replacinf the catridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00442122&lc=en&cc=us&dlc=en&product=441125&lang=en
Jul 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Horizontal Lines
This might be a hardware problem, but it could also be caused by an outdated (or corrupted) driver; you could uninstall the original driver, then download and install the newest version directly from HP here:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=446435&lc=en&jumpid=reg_R1002_USEN
If that link is broken, or doesn't work for you, use this one:
http://tinyurl.com/2n7lge
Also, I've copied the following information directly from the HP 4850 Scanjet user's manual:
If you have the HP Image Zone software installed, you can use the onscreen Help to solve other problems with the scanner. To gain access to the Help, open HP Solution Center, click Help, and then click HP Scanjet 4800 series scanner Help. The Help system provides information about the HP Scanjet 4800 series scanner hardware as well as information about the HP Image Zone and HP Scanning software itself. Also, see Scan troubleshooting in the general Troubleshooting and support section of the Help.
Good luck with this; let us know what you learn...
Jan 26, 2008 | HP Scanjet 4850
148 people viewed this question
old marine
old marine
