Question about HP LaserJet CP1215 Color Printer
Dead all lights are on and printer does not boot
Hello Is Xa.
Quick question: there are 9 possible lights on the CP1215. Are you saying all of these lights come and stay on?
Posted on Apr 22, 2014
Computer wont boot
That sounds like you have a dead hard disk drive if the hard disk drive is dead then you will need to have it replaced there is a way to check if it is dead or not, you will need to go into the bios for most it's usually the hi lighted tab when the bios comes if its dead the hard drive slot should say empty or none if it's not dead it will show the hard drive info
Dec 22, 2012 | Acer Aspire X1200-B1601A PC Desktop
Tip
What to do when your mac doesn't boot
If your Mac does not boot, or is stuck while booting, performing these steps will help you to solve the problem:
First, disconnect all peripherals (printers, cameras, etc...)To make sure your system files are OK, boot the mac holding the shift key to repair disk and to deactivate extensions. If it boots, it will ask for your password. Type your password, if you are able to see the desktop, then your problem can come from a third-party extension. Back-up all your files (mostly located in the home folder) and reinstall your system.
Secondly, if the solution above does not workYou can start to think about a hardware problem. Most of the time, a Mac does not boot because of a dead hard drive. But it can also be a faulty motherboard or RAM. I recommend to test all of these, using your hardware test, following these steps: http://support.apple.com/kb/HT1509 .
At last, If you can't eve test your hardware, think about a dead power supply or a dead motherboard/
on Dec 31, 2009 | Computers & Internet
HP CM1312 DISPLAY DEAD, READY LIGHT SOLID, EXCLAMATION POINT SOLID
I hope its formatter(mother board) faulty,remove USB cable, un install the drivers from the system, found new hard after connecting the printer? if its not recognizing replace formatter assm..or else display panel..Hints while repairing: Flat cable is too short between scanner assm & DC controller, before powering on verify this cable properly fit or not.. While opening the printer side covers by mistake flat cables of ADF & display plug off due to over length, if we are not concentrate on this it will damages the formatter,if we gives power(might be this issue raised in your printer)..Never disturb/remove the laser scanner assm.. it will kill your patience.Never try to remove laser scanner assm with out cartridge bank( for repair normally we will remove this bank), it will fall down on ETB.. verify all connector properly fixed or not before powering on..
Dec 30, 2011 | HP LaserJet CM1312 All-In-One Printer
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
Battery Light flashes twice and does not boot up
Are you plugged in at all? Try with plug plugged in. I think your battery is dead.
Aug 05, 2010 | Acer Computers & Internet
HP 7410 will not boot. It powers up and the HP logo screen flashe
This was solved really well on this blog. It is some problem with the wifi board. If you disconnect it (no so hard and well explained on the blog) you will have network printing over a cable but no wireless.
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
Oct 23, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Mobo does not power up Dead cpu dead mobo?
A dead CPU will not hinder a board from powering up. The board is unlikely to POST. However, you should heard attempts at powering up and immediate shutdown. Or, you will see the PSU comes on but system not boot.
No mobo, but, CPU.
If no failed attempts at boot, no indicator lights, then you have either a failed power supply or DEAD motherboard.
Good luck
Sep 27, 2009 | Fujitsu Siemens Computers & Internet
Printer dead, no lights, not powering up at all
your power supply is probably dead you will have to replace it
Jul 19, 2009 | Lexmark X8350 All-In-One InkJet Printer
Acer 5315
Could be the power supply. (Likely built into the power cord). Heat could have been causing it to fail before. Possibly dead now!
Jul 11, 2009 | Acer Aspire 5100-3357 Notebook
Lexmark 4039 lazer printer will not start
there will be a tube type fuse in pcb check the connectivity if dead replace the same
Jan 24, 2009 | Office Equipment & Supplies
HP LaserJet CP1215 Color Printer Logo
Seeker5211
Seeker5211
