Question about Dishwashers
Asko dishwasher 1705
I am searching for a replacement lower basket for my 1705. Are there other models where the same basket will fit?
    New Friend:
  • 56 Answers
Some places have on sale for right around $100.00USD
Posted on Apr 19, 2014
  • lyn thomas
    lyn thomas Apr 19, 2014
    do you happen to know of any local (Brisbane) places that i could try?
  • Ken Johnston
    Ken Johnston Apr 19, 2014
    MMM sorry mate I don't know that one. mostly work in the upper lower48 states of USA eh!
  • 116 Answers
SOURCE: Asko 1705 Dishwasher won't fill.
The issue is most likely in the fill valve itself(around 90% of the time). This is located behind the toe kick on the right hand side of the machine. the valve can be checked manually by using a jumper cord connected to 110V power and directly attaching it to the valve electrical terminals. First shut off the dishwasher power at the house breaker panel. Remove the electrical connections at the fill valve. attach the jumper cord and power the valve directly. if there is no water entering the machine then the valve needs replacement. If there is water then proceed below.
There have been some issues with wiring to the fill valve. You will have to carefully inspect the wires beneath the toekick for breakage.You will need to have a torx 15 or 20 handy to remove the screws( if installed properly) ther will be several brown or grey wires in a bundle on the lower right hand side beneath the door.
Use extreme caution when working with electrics.
Ideally have a technician verify the problem for you.
Posted on Jul 28, 2008
SOURCE: Asko D1706
I live in Australia, My one had the same problem, I found them in e-Bay.
Posted on Dec 25, 2008
buffalonyman
  • 1865 Answers
SOURCE: how to repair rust on lower basket of dishwasher
Use sandpaper or brillo pad to remove rust, and paint it with acrylic appliance paint
Posted on Apr 15, 2009
glasgowlove
  • 40 Answers
SOURCE: how do i fit a replacement lower door seal on a dishwasher
try here for help
or contact them direct..
http://www.devicemanuals.com/guide/Dishwasher/Indesit-manuals.html
Posted on Oct 29, 2009
Macmarkus
  • 2605 Answers
SOURCE: replace upper basket and bearings on Asko
Welcome to FixYa.
Yes the upper rack is pretty straight forward, but the bearings are tricky.
Here's what works for me, move the rack stops to the left if you haven't already and then the rack itself.
i.e.
1d854c5.jpg and
Now you'll need to remove the bumpers at the back of the rack rail...
i.e.
push down on the bumper as shown
and pull it down and out at the same time...it takes some force as evident by my finger tip ha ha, you can use a small screwdriver...I'm just stubborn.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
The trick now is to install the balls into the holders first...
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done.
Thanks for visitng "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Again, good luck :)
Posted on Sep 23, 2010
Where can I buy new loading baskets for my DWI 160 dishwasher?
These come as several parts. Not sure if all are available anymore as Candy parts. But you can get replacement Hoover parts to fit.
Main basket from Candy
Candy DWI 160W UK Dishwasher Basket
Cutlery basket from Candy
Candy DWI 160W UK Universal Cutlery Basket
The Upper and Lower baskets may not be available from Candy but Hoover replacements are
Candy Use HVR41022779 Lower Basket
Best to ask Candy support to provide pictures of the parts for comparison with your model or purchase or a refund policy if not suitable.
There is another site worth checking (but prices seem high)
CANDY DISHWASHER BASKET LOWER for DWI160W UK
Sep 23, 2014 | Candy Dishwashers
I have a Asko D3530 and the top basket isn't washing properly but in my menu section it doesn't come up upper basket wash anymore?? If someone could tell me how to get that option back that wo
Keep the Program button pressed until you see wash programs like Auto or Normal displayed. This should get rid of the Lower basket program.
Manual is available from here
Jun 27, 2012 | Asko 24 in. D3530 Stainless Steel...
Does anyone know where to buy replacement cutlery basket for Asko D3100?
They are sold by dimensions and you can find them here in the UK:
http://www.partmaster.co.uk/cgi-bin/search.pl?query=Asko%20asko%20cutlery%20basket&f=522778&path=104426&shop=asko
AU
http://spares.bigwarehouse.com.au/index.php?cPath=69465_69466_81477
Actual part number 8801239-77
another AU site part listed more than 50% down the page using the PN above:
http://www.albury.net.au/~allfix/catalogs/dishwash.htm
Sure does seem a bit pricey on the AU sites....
To me as a 40 year tech a dishwasher cutlery basket is a cutlery basket. Find one that will fit the dimesions of your dishrack alloted cutlery basket space and buy it. The first link is a good start.
Kelly
Apr 16, 2011 | Asko D3251FI Dishwasher
Asko dw 95.2 model 1705 after 6 years of use the dishwasher top drawer rolls out. Will not stay inside when main door is open.
Check the level and tightness of the slide rails--they may have come loose after the years of use. Make sure the dishwasher case itself is level. Hope this helps!
Jun 29, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Wheels have fallen off the bottom loading tray, where can I get more?
www.asko.com, select your market- list of stockists can be accessed. Alternatively, search your local online business directory for an Asko Service Agent- parts are readily available, and easy to fit
Aug 03, 2009 | Asko D1716 Built-in Dishwasher
Asko D1706
Jul 06, 2008 | Asko D1706 Built-in Dishwasher
My Asea 1502 Dishwasher gets most of the way through a cycle then stops with lights flashing. It is empty of water. What is the problem?
Further to my problem with my 19 year old ASKO ASEA D1502 Dishwasher .
I found a Use & Care Guide online at the ASKO site:
http://www.asko.com.au/downloads/manuals/
(It is an 8MB PDF, only 20 pages scanned)
The manual says flashing lights in the combo I had indicate heater fault.
Manual has good test procedure and I followed that and it showed that the Heater is OK.
Machine works through full cycle but flashes at the end.
It is an old machine so I suppose I just live with it unless anyone has any suggestions.
Apr 23, 2008 | Dishwashers
Asko d3530 dishwasher
theres two plastic clips at the front of the rails,turn them to the side and the basket will come out
Feb 29, 2008 | Asko 24 in. D3530FI Built-in Dishwasher
Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Nov 17, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
