Question about SuperMicro X7DA8 Server Board - X7DA8-B Motherboard
Date/time date and time are lost, even after replacement of battery, Can else can be wrong ?
  • 82 Answers
There may be a bad connection in the CMOS battery housing. The battery should make an audible click when it's pressed into the CMOS housing on the motherboard. First, I would make sure that the motherboard BIOS has the latest version R2.1c found here:
Super Micro Computer Inc Products Motherboards Xeon Boards X7DA8
If you can't locate a bad CMOS terminal, you may need to RMA the motherboard. You can check the warranty status here:
http://www.supermicro.com/support/rma/
Posted on Apr 21, 2014
Date time not set
When you change the date and Time to the correct Date and Time and when you next boot up the laptop the Date and Time is lost. Then this is caused by a flat BIOS battery which cannot keep these setting stored in the BIOS.
Replace the BIOS battery then go into the BIOS setting to set the Date and Time and this will fix your problem.
Apr 18, 2012 | Computers & Internet
Tip
How to verify that the CMOS battery needs to replace
<p>The CMOS battery is named after the Complementary Metal Oxide Semiconductor power. The CMOS has the current date and time functions for desktop and laptop computers. It allows the computer to automatically adjust the time, even on computers that are disconnected for long time. When a computer no longer has the date and time and forget it on every boot, the CMOS battery probably needs replacing. Some computers have messages when the battery is weak, while others just lose the current date and time after each shutdown.<br /> <p>Time & Date Errors<span> </span><br /> <p><span> </span><br /> <p>1. Turn on the computer. Look in the task bar at the bottom right. Make sure the date and time is set correctly. Double-click the time and click the up or down arrow to switch to the correct time. Click on the arrow next to month to change the month. Click "OK" when finished.<br /> <p><br /> <p>2. Turn off the computer. Wait 3 to 5 minutes and start the machine.<br /> <p><br /> <p>3. Look on the taskbar to see if time was lost and said a strange date January 1, 2000. Replace the CMOS battery, if this is the case.<br /> <p><br /> <p>CMOS Error Message<br /> <p>1. Look for error messages like "CMOS checksum error", "CMOS Read Error" or "CMOS battery failure" when you start your computer. These errors are caused in the machines shut down for several months or when the CMOS must be replaced.<br /> <p><br /> <p>2. Let the computer on for 24 hours. Restart the computer and find the error.<br /> <p><br /> <p>3. Change the CMOS as the return error.<br />
on Jun 21, 2011 | Computers & Internet
Date and time is not right tried to fix in
If you fixed the Date and Time in the BIOS and when you boot up the laptop next time the Date and Time is wrong, then most like the BIOS battery is flat and needs replacing.
After the BIOS battery has been replaced go to the Bios and set the Date and Time.
Apr 16, 2012 | HP Computers & Internet
Time and date
Apr 16, 2012 | Computers & Internet
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
Dec 31, 2010 | Canon PowerShot A480 Digital Camera
Battry
The BIOS battery keeps the Date and Time correct, if the battery is flat the date and time will be wrong or you will get an error date and time error.
You need to replace the battery with a new one. Your friendly computer shop can help you if you don't know how to change the battery.
Sep 28, 2009 | ASI CL51-15 Notebook
Set the date on nuvi 350
April Fools day!
If you are turning the GPS OFF by master switch this information will be lost always.
If just using the front buttons then it will remain as you set it There is no spearate power memory for when the unit ges flat from main battery or having a separate memory battery
Jul 23, 2009 | Garmin nuvi 350 GPS Receiver
IBM thinkpad 600x
The battery that might be dead is not the main battery. It's the cmos battery, which is a coin cell battery located on the motherborad. It stores the setting in the bios and keeps the date and time accurate. Errors 161 and 163 mean the date and time are wrong. If the cmos battery is dead then, the date and time go back to 1/1/2000 every time the pc is restarted. Thus, you get the "wrong date and time" errors 161 and 163.
Dave
Jul 24, 2008 | IBM ThinkPad 600X Notebook
SuperMicro X7DA8 Server Board - X7DA8-B Motherboard Logo
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
