Defy manual laundromat 1300m washer not spinning
I have a Defy Laundromaid 1300m that doesn't let water in or start with the washing cycle need help please
Sounds like your inlet valve isn't opening. With it not opening the cycle won't start by default.
May 11, 2017 | Washing Machines
I have Defy laundromat 1100. .the machine can no longer drain water after a wash
either the pump is bad or the PCB has failed .call a repair service
Dec 27, 2016 | Washing Machines
My defy laundromaid 1300m does not stop water flow, even not in use water keep flowing into the machine
there are shutoff valves behind it . use them till you get the other valves replaced
Dec 20, 2016 | Washing Machines
Defy twinmaid 800 spinner rotate very slow
Wiring diagram for a defy Twinmaid 800 washing machiine?
howtomendit.com > Household Appliances, Washing Machines Free repair help - wiring diagram defy twinmaid 800 washing machiine. ... machine spins very very slow sometimes and sometimes it doesn't spin help please.
Jul 24, 2015 | Washing Machines
How to wash down
Hello.. I do not recommend trying to wash a down comforter in this washer. It will not wash correctly and more than likely will not spin out. Your best bet is to take the item to a local laundromat and use a large 50lb washer if available.
Apr 28, 2014 | LG 3.7 cu. ft. Front-Load Washer - WM2240C
I have Defy Laundromaid 1300. I was getting an E9 message.
Hi, I get an OD (wording) on my machine after washing-dosnt rinse or spin... what can that be???
DEFY LANNDROMAID 1300M!!!
Sep 21, 2010 | Washing Machines
How can I get my washing machine to spin and empty with bad timer
Emptying the tub is easy, just lower the drain hose into a bucket on the floor, or into a floor drain. If the timer can be operated manually, turn it to spin, then drain after spinning a while. If this is an electronic timer, you will need to remove the clothes and take to a laundromat or a friend's house to spin the water out.
Dec 03, 2009 | Washing Machines
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
