Question about The Times Case Corporation Tractors International Harvestor
Case 895 4 wheel drive wont engage - The Times Case Corporation Tractors International Harvestor
My 2009 mahindra pik up wont go into low range 4wd
Try replacing the motor on the back of the transfer case that engages high/low, which should fix the issue.
Feb 16, 2016 | Mahindra Cars & Trucks
Have a 1985 chevy s10 pick up & the 4 wheel drive wont engage. I already replaced the solenoid on top of the transfer case, & it still wont engage. I can hear the transfer case engage & I have vacum at the...
Make sure that the vacuum hose connector is connected AND connected correctly at the transfer case and at the front differential. If that is all right and the front differential still doesn't engage, then you need to test the vacuum actuator at the front differential.
Oct 25, 2013 | 1985 Chevrolet S-10 Blazer
Not a problem as much as an answer. Are both wheels rear wheels engaged at all times on my 4x4 87 ranger?
this is a rear wheel drive vehicle and as such the rear wheels are always engaged.when in 4 wheel drive the transfer case in gages and the front differential connects and is engaged.unless the 4 wheel drive is engaged the transfer case just free wheels.
Apr 27, 2011 | 1987 Ford Ranger
4x4 front end not engaging
my computer problem is hard disk system found warantty hard disk
Feb 24, 2010 | 2006 Ford F-150
Four wheel drive wont engage. Tranfer case is
Sounds like you either have a vaccum leak or your 4 wheel drive actuator is not working to engage the front differential.On my 98 ram there is a black and red plastic lines that are used for the vaccum lines. They are underneath and go from the transfer case to the front axle, check to see if one or both might be cracked or broke completely.If the lines are good then it could be your actuator on the front axle. A new one is about $93 at advance auto parts and not very hard to replace
Dec 15, 2009 | 1998 Dodge Ram 1500 4WD
1988 ford ranger push button four wheel drive an it wont engage all the wires are good it just clicks when u push the button.. what should i look for to make the four wheel drive work again it wont...
Start out with buying yourself a $25 book from the Parts House. The I would go to the front HUBS, secure & safety vehicle before you do anything, Clean, Inspect, Lune & Repair front Hubs as required, get the brakes while you're there. Check your drive line, axles, u-joints etc. Clean , repair , replace as needed. Check for Tranfer case Operation. Is there power going to the front Axle when 4WD is engaged? do you feel a change when you engage the Transfer Case? Have you checked the Power on the circuits? Have you Manual or Auto-locking Front Hubs? Answer all those Questions & read before you do anything.
Nov 03, 2009 | 1988 Ford Ranger
My four wheel drive on my Navajo will not engage
something is wrong with the pushbutton or there is something not working when computer comunicates with tranny/tranfer case
May 06, 2009 | MTX Ford Explorer/Mercury...
4x4 wont engage
the motor on the back of the transfer case may be stuck knock on the motor lightly with a hammer when switching the the switch May need a motor
Mar 03, 2009 | 1999 Chevrolet Silverado 1500
4 wheel drive problem on Jeep YJ
you can also check the 4 wheel drive vacuum switch on top of the transfer case...got mine for 10 bucks from parts store...fixed the problem
Dec 21, 2008 | 1992 Jeep Wrangler
The Times Case Corporation Tractors International Harvestor Logo
Top The Times Toys Experts
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
