Question about Garden
White and grey under leaves - Garden
1996 jeep Cherokee country 130k miles recently had oil filter changed and broke the oil sensor gauge...had them replace gauge sensor causing the new filter to be reinstalled. Several weeks later after two...
There is either A).an oil leak or B). the smoke is from residue oil spilled on exhaust and such during the repair. Crank the engine and look everywhere for an evident oil leak if one is not found leave it run till it gets hot enough to show where the white smoke is coming from and see then if it is residue or a new leak. Remember to rate my answer and leave testimony this is how we earn our milestones here of FixYa remember we are all volunteers here so answers may not come as fast as you like please be patient thanks in advance.
Sep 30, 2013 | Jeep Cherokee Cars & Trucks
Unit will not stay on programed stations every time turn on have to set a station to listen to
Hi Jackie,
This is usually the result of connecting both ORANGE and RED 12VDC (+) wires to a "switched" source (meaning it is powered only when the ignition is in the on / run / accessory position).
The radio instructions specify the following connections:
Orange = +12V constant
Red = +12V switched
Black = ground
Blue/white = remote on
Green/Black = Left Front -
Green = Left Front +
Grey/Black = Right Front -
Grey = Right Front +
Black/White = Right Rear -
Grey/Red = Right Rear +
Black/Green = Left Rear -
Green/Red = Left Rear +
If you disconnect the ORANGE wire from whatever you have it currently connected to - and connect it directly to the battery's 12V (+) terminal (or other source that has 12V (+) with the key removed), your station memories will be retained.
Leave the RED wire where it is, so that the radio will shut off whenever the key is taken from the ignition - and you won't be stuck with a dead battery in the morning.
Sep 17, 2013 | Pioneer DEH-245 CD Changer
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
My colored cartidge is out and my black is full. I went in under maintenance and changed it to balck only and printer preferences and changed it to grey scale. it still wont print black only
Some printers simply will not work if one of the cartridges is empty, even if you are not printing with the cartridge. The other catch might be is that some printers create grey scale by mixing colors so you might want to turn off grey scale and try printing just black and white.
Apr 13, 2011 | Computers & Internet
Witch one is the power wire
Fuse 23 and 13 in the battery junction box under the hood powers the A/C clutch relay in the same fuse box powers the A/C clutch diode in the same fuse box then goes to the A/C clutch the grey /white wire is power and the black is ground
Apr 12, 2010 | 2002 Ford F150 Regular Cab
Grey shading on page??
At first. clean the optic. Change the developoer. if no good? Cange toner - it is the soft way. Then photo drum. its may be not espensive if you calling to service. Clealing the coronat first and the second. There are no nothing
Mar 13, 2010 | Canon NP 7130 Black and White Copier
I HAVE A KENWOOD KRC-2007 CAR STEREO AND DON'T KNOW WHICH COLORED WIRE GOES TO THE LEFT AND RIGHT FRONT SPEAKERS, I THOUGHT IT WAS WHITE/WHITE BLACK AND GREY/GREY BLACK.
Hello! Front Right; + = Grey... - = Grey/White
Front Left= + = White... - = White/Black
You are correct...Perhaps you need the vehicle's colors?
If so send a comment with year, make and model...
Guru.....saailer
Feb 17, 2010 | Vehicle Parts & Accessories
Grey scum marking clothes
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Mar 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
