Question about 2001 Daewoo Lanos - 3-door hatchback - Weathershield HP Car Cover
How to remove door vynyl lanos
Have problem removing vinyl at door catch on right hand door.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 63 Answers
Use your wife's hair dryer to heat the plastic. Then, slowly unapply.
Posted on May 02, 2014
2002 Ford Escape Vinyl Panel on Interior Front doors Unglued
I would have an Auto Upholstery Shop remove your
door panels & just redo them the way you would like
Jul 26, 2013 | 2002 Ford Escape
Painter has left small line of white vinyl matt emulsion (from ceiling -no masking tape used ) along the top left hand edge of the new stainless steel cooker hood - out of eye line but visible. how can I...
Luckily, vinyl matt emulsion paint is water based and is fairly easy to remove. Use half a wooden garden washing line peg or similar piece of softwood with s mild solution of washing up liquid. The wood will rub the paint off the metalwork and the washing liqid will lubricate without the metalwork so not to damage it.
Hope this helps.
Nov 25, 2010 | Microwave Ovens
How to remove ford door panel au11 2001. window will not go up or down
My AU11 is a XR8 with premium sound. I say this because maybe the speakers in the doors change the way the door panel is removed. I am describing the front door panel removal.
1. Remove the door lock knob by pulling it up.
2. Remove the two screw covers covering the screws which are above the speakers by gently prizing them out with a screwdriver.
3. Under one of the covers (the one closest to the speaker) is a 10mm bolt, remove this bolt by using a small 10mm socket.
4. Remove the two screw covers on the bottom of the door and remove the two phillips screws underneath.
5. Remove the phillips screw that is near the door lock knob but on the centre pillar side of the door panel. This screw is the only one that is not under a removable cover.
6. Remove the door release bezel by gently prizing the top of the bezel between the vinyl and the bezel with a screwdriver. For this you need to be gentle in order not to damage the vinyl.
7. Once the bezel is off you can see another 10mm bolt underneath that must be removed.
8. Gently prize up the electric window switches. I prized mine up carefully by using a screwdriver in the gap between the armrest and the electric switch panel. Unplug the electric switch panel which is a captive plug so you need to use a screwdriver to release the catch. You can also do the same for the electric mirror plug once the door panel is off.
9. Under the electric switch panel is another phillips screw that must be removed.
10. The door panel can now be removed by gently prizing it away from the door. I just used my hands for this but maybe you will need a wooden spatula or similar to assist. The door panel will offer some resistance and pop once the clips release. If you encounter strong resistance maybe you have another clip or screw etc that needs to be located.
Dont forget to unplug the electric mirror wires.
Jul 28, 2010 | Ford Futura Cars & Trucks
HOW TO ASSEMBLE MY WASHING DOOR CATCH,SPRING AND CATCH MODEL NOHNF 7138-80
Just open the front door of the unit and remove the rubber sleeve from the front cover you will find the iron ring just remove it first then you can easily remove the rubber sleeve and then you will see the two screws which holds the door lock switch just remove it and hold the door lock switch with the hand and see the wire connection properly when you are refixing it the door lock will work properly
Jan 05, 2010 | Washing Machines
Front driver's door won't lock on my 1999 Daewoo Lanos SE
it is attached with a wire clip and there s a very affordable removal tool which slips behind the crank handle and pushes it out....it can be dug out with a hook scribe but a bit frustrating and can cause minor damage to the trim
Jul 01, 2009 | 2000 Daewoo Lanos
Binding brake
hand brake cable adjuster lives under centre console at rear 10mm spanner required unadjust this and then remove rear drums to adjust linings so they just drag on drum then go back and adjust cable in car
Jun 03, 2009 | 1999 Daewoo Lanos
How to remove drivers door panel and window winder
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Jun 02, 2009 | 2000 Daewoo Lanos
Replaced timing belt not running right
The Lanos engine are an interference engine. If you have bent valves, remove a plug wire one at a time and see if there is no change in the idle. My guess, one of them isn't going to change anything. That would be the cylinder that has the bent valves in. I had a Lanos in my shop with a broken timing belt and the head had several bent valves. I wouldn't be surprised at all if you also have bent valves.
Jan 29, 2009 | 1999 Daewoo Lanos
Hotpoint CTD00 Door Catch Replacement
If yuo are referring to the catch on the door, then undo all the scews holding the 2 halves of the door together, and prize apart, fit new door catch.
If you mean the door lock, then you will have to remove the top cover and right hand side panel to access the door lock.
Hope this helps.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Dryers
FRI/FWT449GFS Front load washer manuf in 1999
The interlock is going, Ifr you want to repair Unplug machine. open door and remove just the front part of the door seal, theres probably a metal band around it. where the door catch closes you will see two screws, remove these keeping you other hand around the back, behind screws holding the plastic interlock, there will be three wires attached to this or a plug remove these, remembring where they go, and take the interlock to the local shop. they cost no more than 20 pound
Nov 16, 2007 | Frigidaire ATF6000ES Front Load Washer
2001 Daewoo Lanos - 3-door hatchback - Weathershield HP Car Cover Logo
59 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
ptpumpman
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
