Question about Xerox Office Equipment & Supplies
Xerox 3250 factory reset
Print server password reset
4 Suggested Answers
  • 2072 Answers
SOURCE: How do I reset a Xerox Phaser 4500 Centreware
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Posted on Mar 03, 2010
SOURCE: How do I perform a factory reset on a Xerox device
lol m looking for the same thing if u have found the answer can you please post it here ?
Posted on Jul 21, 2010
puertobori
  • 7733 Answers
SOURCE: LP 2844Z print server II can't be found. I reset
Technical Support & Repair Services - Zebra barcode and card printers
Posted on Oct 20, 2010
Reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
Reset to factory settings xerox phaser 3250
Reset to factory settings xerox phaser 3250 - Fixya
www.fixya.com/.../t12176778-reset_factory_settings_xerox_phaser_325...
Mar 26, 2012 - A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without ...
Mar 26, 2012 | Xerox Office Equipment & Supplies
I want to reset the print server D-Link DP-301P+. I forgot IP address which I was changed according to network settings.
There are two steps that we can suggest,
A)
1) Install the psadmin software if you have not already. If you have lost the psadmin software then search for it on the web.
2) Start the psadmin software and click "factory reset".
3) If the software demands a password, try "SYSxxxx", where xxxx stands for the last four digits of the MAC address located on the underside of your server. (Example: if your MAC address were "63 XE 29 44 F2 96", then your password would be SYSF296.)
4) Click yes to confirm the reset.
B)
On the back of the print server you will find a pin hole, insert a paper clip for 30 secs with the print server powered on. All lights will flash. Try to setup the server again.
Hope this helps.
Regards,
Shrey
Jun 01, 2011 | D-Link DP 301P (DP-301P) Print Server
Express EtherNetwork DP-301P+ Print Server: DP-301P+ how to resert the ip and password...
for you to reset to factory default you must have the original cd that came with it, it's called PS admin Version 3.0 the process takes a second to gain your Print server back to factory default.... if you want it reply to this with your email address i will forward the executable file to you...
May 17, 2010 | D-Link Express EtherNetwork DP-301P+ Print...
Factory reset brother nc 2010h
Same problem, did you find a solution ?
Pascal
Nov 11, 2009 | Brother (NC-2010H) Print Server
How can I reset my printer derver dp-300 to factory defualt values? Close
how reset password for dlink 300 print server please give me solution
Nov 11, 2009 | D-Link DP 300U (DP-300U) Print Server
A reset problem
Try using the PSAdmin software to do a factory reset (download it from the internet if you need to). If it demands a password try the following:
password: SYSXXXX (Where XXXX is the last four digits of the MAC address, which can seen on the underside of the server)
I learned about the password part from http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten, which has additional helpful details.
Jun 17, 2009 | D-Link DP 300U (DP-300U) Print Server
Reset factory setting
Try consulting the manual for the printer:
http://www.retrevo.com/support/CNet-CNP-430-manual/id/8366bh135/t/2/
Dec 18, 2008 | Cnet CNP 430 (CNP430) Print Server
We forgot the password
try this and see if it works for you please email me and let me know first To reset the print server using PS admin follow the steps given below: ----------------------------------------------------------------------------------- Step 1 Open the PS Admin software, select the print server you wish to reset to factory defaults, and then click Factory Reset. Step 2 Click Yes. Step 3 Once the reset procedure has been completed, Click OK. The device is now set to factory default settings. For D-Link's preferred Home Networking application please try http://www.networkmagic.com/nmlp/dlinksupport.php from Pure Networks. It simplifies Microsoft Networking and may allow you to trouble shoot your network on your own. like i sai dtry this and let me know thanks keith
Sep 19, 2007 | D-Link DP 303 (DP-303) Print Server
50 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
