FixYa.com
Tags:
Freezers
Generic problem for all Freezers
Freezer making noise & left side of the freezer (on...
posted by redlady4850 on Nov 02, 2007
GE upright frost free 20.3 cu.ft. freezer,  model #FUF20DACRWH, manufactured in 09/98.  Freezer located in basement of house.  Never had problems.  Two weeks ago, I opened freezer and searched for item.  Since I had door open, the motor began to run to keep freezer at correct temperature.  When freezer began to run, the noise was unusual from what it has always been.  It was a whining noise, then a scratchy noise.  I closed the freezer door and after a couple of minutes the noise stopped.  For past two weeks, I will hear the noise when I am upstairs.  I will go to basement and slap the back of the freezer and the noise stops.  Throughout the day, the noise will come and go.  The past 2 days, it has been more frequent.  Normally the outside of freezer on the left (as you face the freezer) is a little warm, but it is now very warm to the touch.  To date, the freezer is the same cold temperature inside as always.      I have investigated the problems as follows:
I listened to see if I could determine where the noise is located.  Today, I removed some of the items from mid to bottom of freezer.  I heard the noise coming from behind the panel to the evaporator fan area.  I removed the panel screws and opened it and it was where the noise is coming from.  So far, I have not been able to get the noise to reproduce.  It is coming from that area.  When I adjusted the temperature and got the freezer motor to come on to keep the temp cold, the evaporator fan was running, but of course, the noise never reproduced.  I just placed the panel back against the evaporator fan and have the freezer on the same temperature as always and I am waiting for the noise to occur again.    I don't know if the evaporator fan is getting stuck or not.  Can't figure it out ---will be better when the noise happens again.   My concern is the outside of the freezer on the left side is very warm---probably twice as warm as it should be.   (I have another freezer in the same room and the left side of it is the normal slightly warm temp.)      I am concerned that when I am not home something could happen to freezer.  Please help---sorry for long post.  I am not that experienced in appliances, but went to appliancehelp.com and found the diagrams for my freezer with parts that can be ordered.  Problem:  I don't know what parts do what---- and what symtoms indicate that a particular parts is not working properly.      thanks for help   -- not familiar with this website and how you respond.  My e-mail is einig1@netzero.net.        Thanks,   Debbie
Comment by redlady4850, posted on Nov 02, 2007
I realize now that I need to sign-up and then check back to see if anyone offered a solution.  Will check back to website  -- any advice will be appreciated.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 03, 2007
Not Rated (0)
dididsaythat
Rank:Wiz Wiz
Rating: 83%, 395 votes
Sounds like the freezer evapurator fan... they make noise on and off at times when bears are wore... Thats about the only thing that can make noise inthe area ur talking about.. if noise comes back listen where the freezer fan is.. is most liklly the problem
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH GE 11.6 cu. ft. / 328 liter Upright Freezer FUM12SM GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR GE 14.8 cu. ft. / 419 liter Chest Freezer FCM15DMWH GE 14.8 cu. ft. General Electric Chest Freezer FCM15PUWW GE 16.7 cu. ft. General Electric Upright Freezer FUF17SUR Electrolux 16.8 cu. ft. Upright Freezer Professional E32AF75FPS
Can you Help with these Freezers problems?
Freezers
U-line undercounter freezer
Two drawer - cannot open... Answer This...
Freezers
servis fridge freezer
there is a red light above the... Answer This...
Frigidaire 13.7 cu. ft. / 388 liter Upright...
DRIP PAN
Our refrigerator door was not... Answer This...
Hoshizaki Freezer Commercial Ice Machines -...
hoshizaki F-800 MAH
Need to know were the violet,... Answer This...
Freezers
Kenmore Freezer Temp. Alarm
Temp Alarm come on for no... Answer This...
Repair Service
Find Freezer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
