Question about Samsung Galaxy S Duos S7562 White Dual SIM Unlocked
Internet my mobile is internet concetione is very selow and money over cating how to edite internet?
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap thePower button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
Posted on Jul 04, 2014
Nokia N80 internet edition on Orange. How to use on Tmobile
Hello. If you want to use T-mobile network on your Orange network locked Nokia N80 internet edition, The device must be unlocked in prior. You can unlock it safer and easier using unlock code. You can get the accurate unlock code for your Nokia N80 internet edition from Mobile-Unlocker.com at affordable cost with an easy unlocking guide. Good luck.
Sep 18, 2014 | Nokia N80 Cellular Phone
Certificate missing on phone or sim nokia c3-01. does any body has a solution?
Please Go to sim Offfice And Double Cate Sim and Go to mobile and take a new Mobile .
Aug 08, 2012 | Nokia Cell Phones
How do i set my gprs on my i9
These are the settings for AT&T, T-Mobile settings are provided next (search google or email me for other providers):
At&t WAP Setup
***First Step***
1.Main menu --> Select Services
2.Select Data Account --> Select GPRS
3.Select the first entry
4.Edit the account name to whatever you would like
5.Edit APN to wap.cingular (lowercase)
6.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
7.Edit Password to CINGULAR1 (UPPERCASE)
8.Edit Auth Type. to Secure
9. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
2.Select the first entry --> Edit Profile
3.Edit the name to whatever you would like
4.Edit Homepage to http://device.home
5.Edit Data Account to the Name you established in the First Step
6.Edit Connection type to HTTP
7.The IP address is 066.209.011.032 and the port number is 8080
8.Edit Username to WAP@CINGULARGPRS.COM
9.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
To access the net select Services --> WAP --> Homepage.
If it connects the Black [G] should turn Green
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Now for T-Mobile:
From the Main Menu select Entertainment > Services > WAPmag-glass_10x10.gif > Settings
(NOTE: On some devices Entertainment is no longer listed go straight to Services)
Select Edit Profile
Scroll to an empty profile (IE: Profile 8) and select Edit Profile
Set Profile Name to T-Mobile Internet
Set Homepage to http://www.t-mobile.com or http://www.google.com
Select Data Account > GPRSmag-glass_10x10.gif > T-Mobile Internet
Set Connection Type to HTTP
Leave Proxy blank
Leave Port blank
Leave Username and Password blank
Press Done
When Prompted to Save select Yes
Scroll to T-Mobile Internet and select Activate Profile
Aug 10, 2010 | Dual Electronics CECT P168 Cellular Phone
I have the Fly-Ying F026 and im under a tmobile plan, im unable to connect to the internet.
Check your connection settings.
I believe these are the defaults: GPRS APN: - internet2.voicestream.com
Username: - {blank}
Password: - {blank}
DNS: - 216.155.175.105, 216.155.175.106
for {blank} just leave it empty.
Dec 18, 2009 | Cell Phones
CECT i9 Phone: GPRS problems...
the info is for cect phone p168, (but will work) this link will give you yahoo (sports, mail,weather) and cnn news http://www.youtube.com/watch?v=og0bgJCeC1k if you have data plan with tmo you will have a full internet service.if this help you feel free to rate have fun
May 08, 2009 | Dual Electronics CECT P168 Cellular Phone
I68+ cellphone
1: WAP
Setting
Select SIM 1 or 2 depend where you place your sim
Edit Profile
T-mobile internet
Homepage...http://wap.myvoicestream.com
Data account: GPRS
connection type. Select http
proxy address216.155.165.050
proxy port: 8080
2. Data Account.
Select GPRS
edit GPRS
Account name GPRS
Edit APN: WAP.VOICESTREAM.COM
Auth. Type
Select: SECURE
Apr 08, 2009 | Dual Electronics CECT P168 Cellular Phone
I Have NKTEL A500and airtel sim how can i connect the gprs
i have also NKTEL A500 china mobile and i have airtel sim card,how can i connect to the internet(GPRS)?.Please Help me
Mar 26, 2009 | Handmark Software MobileLists (950142) for...
I9 cellphone china iphone clone
At&t WAP Setup
***First Step***
9. Save
***Second Step***
Select WAP
Select back or done
MMS
Select Edit Profile
Select Done or Save
For all of you guys out there that need to setup your internet on the cect I9, using att service. drinks.gif 2thumbsup.gif lolup.gif angel.gif
Oct 10, 2008 | Dual Electronics CECT P168 Cellular Phone
Using internet on w726 pda mobile
Go to Services
select Data Account
select GPRS
select any of the available accounts and click edit
Enter following values against
Account Name Any name u Wish
APN portalnmms
keep username and Password blank
Auth Tyoe Normal
Select Internet Services
Select settings
Select Edit Profile
Select the name u hv updated above
Start Surfing
Jul 31, 2008 | Computers & Internet
Samsung Galaxy S Duos S7562 White Dual SIM Unlocked Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
