Question about LG Studioworks 45 14" CRT Monitor
Zenith monitor z775cp what is the default setting my monitor's setting are not right pllease help me
  • OneElite Apr 20, 2014
    Picture?
Zenith factory reset
Hi Rebecca,
Specific reset instructions will vary depending on the model of your Zenith television. For many Zenith TVs you can reset to manufacturer defaults by pressing 'Menu' then press '9, 8, 7, 6, Enter.' If this doesn't work for your set, try a hard reset: unplug your television and leave it unplugged for at least 4 hours.
You can also try this:
Instructions
    • 1 Press the "Menu" button on your remote control. Use the up and down arrow buttons to highlight the video option. Press the arrow that points to the right to select the video option.
    • 2 Use the up and down arrow to highlight the video reset option. Push the right arrow button on the remote control to select video reset.
    • 3 Press the right arrow button on the remote control to return the video to original values.
Read more: http://www.ehow.com/how_8528201_do-reset-zenith-tv.html#ixzz316gKG3ra
May 08, 2014 | RCA 50in Tv M50 Wh 92s Dlp Hdtv Works But...
How do i get the progressive scan off
Once the setting for progressive scan output is entered, an image will only be visible on a progressive scan compatible TV or monitor.
If you set Progressive Scan to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc tray. See that 'dISC' is displayed on the display window.
2) Press STOP (on front of unit) and hold it for more than five seconds before releasing it (10 seconds is better).
The video output should be restored to the standard default setting (interlace) and a picture will once again be visible on a conventional analogue TV or monitor.
Hopefully that solves your problem.
Apr 02, 2011 | Zenith XBV442 DVD Player/VCR
I have a zenith tv hooked up to my computer and i need a monitor driver for it so i can make the settings right now it is using default driver
Make sure Your computer is upto date with the hook up as a monitor setup from the television.If so then do an online search for the drivedr to make it work.
Aug 01, 2009 | Televison & Video
Monitor screen is vibrat left-right & up-down side
just go to the menu of your monitor then try to reset the setting so it will set the factory default value
hope this will help u
May 29, 2009 | Computers & Internet
Zenith CRT monitor- Z775CP
hay ..my zenith crt monitor does not show any photo with its true colour.. photos are somewhat black not the right brightnes is seen.
can u help me....
Jul 04, 2008 | Zenith L13V36 13" Flat Panel LCD Monitor
Default settings
try using the default button on the top right side of the settings page
May 12, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Changing the default channel
I believe you will have to have a tv tech. do this adj. , this is set in the factory service menu which he or she can access.
Nov 27, 2007 | Zenith H27E35DT 27" TV
LG Studioworks 45 14" CRT Monitor Logo
24 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
