Question about Maytag Atlantis MAV6000 Top Load Washer
Replaced motor but didnt see where the spring goes can figure it
Mod# mav6300aww how to put back spring for the motor/belt its not a normal round spring its a peice of bent metal
    Problem Solver:
  • 12 Answers
What kinda motor did you replace?
Posted on Jun 19, 2009
How do you install the belt on clothes dryer
usually goes in a 'Z' type shape. around drum to around motor drive, then push spring loaded wheel towards motor drive and hook belt over that for tension. of course this is all done by feel for the most part because you cannot see well while trying to put it on. good luck
Mar 15, 2015 | Dryers
Washing machine not spinning
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Nov 01, 2007 | GE WJSE3110A Top Load Washer
How can iget the belt back on my turntable pioneer pl 990
PUT IT ROUND THE PLATTER BASE FIRST,THEN LOOP A BIT OF STRING ROUND THE BELT LONG ENOUGH, SO WHEN YOU PUT THE PLATTER BACK ON,YOU CAN LIFT IT UP A LITTLE BIT WHERE THE MOTOR WHEEL IS THAT TURNS THE BELT, PULL THE STRING TOWARDS IT SO THE BELT GOES OVER IT.DROP THE PLATTER THEN PULL THE STRING OUT.
Mar 31, 2011 | Pioneer PL-990 Turntable
Where does the spring belt tension go on my simpson ezi loader dryer??? I was replacing the drum belt and it flicked off and I didnt see from where. A picture would be good.
the motor is spring loaded - move lift motor towrards the cabinet lining to the right. Put band around drum and pully at rear of motor then allow motor to move back onto band to cause the tension
Feb 17, 2011 | Dryers
How do you put the belt back on? It was making a screeching sound so I took it apart and now cannot figure out to get the belt tight. I have it back on and back together but do not know how to get the...
you have to open back panel of dryer as well as the top. there will be a spring connected to the motor assembly. unlatch it, check your belt to see if it needs to be replaced. if cracked, replace. latch spring and belt should have tension.
Oct 25, 2010 | GE DWSR463EG Electric Dryer
The drum of my Zanussi TC7103 was making a knocking noise and has now also stopped spinning i have removed the side and the drive belt is fine. The belt loops the drum and then goes round a black plastic...
yes you can replace the belt tentioner . disconnect capacitor wires remove the spring off the motor slip the belt behind the pulley so the motor can move round. remove the rear fan cover ( screw and retaining clips) this to allow pulley to be slid off. fit new tentioner pulley and pull belt in front of pulley refit spring to motor down to cabinet.reconnect capacitor. refit fan cover.125 01 25-20/8 is part no for one of 12 variations of this model use the product no to get the right part 916xxxxxx
Aug 26, 2010 | Zanussi Dryers
The belts come off, its a hotpoint aquarius wm63.
Remove the complete rear panel of m/c if it is a washer dryer, you will see the drum pulley in the center, and the motor pulley is at the top of the m/c
Put belt round motor pulley first, and feed belt round drum pulley.
If it is a washer on its own, remove the small center cover at rear of washer, and remove top cover also.
Put belt round motor pulley first and carefully feed belt round drum pulley, you will find this easier to do if you unhook the rear retaining spring.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WD63 Front Load...
Replace serpintine belt
You shouldn't need to most of the time all you need is a 15mm wrench. Use it by turning the spring tightener inward toward the center of the motor than the belt should come off. Also when you take it off make sure you know how the belt goes around the pulleys so everything will work together like normal. when putting the belt on you should use the wrench to turn the tightener back inward and slip the belt back on and make sure it looks just like the old one when its on.
Jan 12, 2009 | 2003 Toyota Corolla
Dryer belt routing
the best way i can tell you is open the back put the belt on the motor then visually pull the tension pulley back and put the belt on the tension back on the belt. if you are changing the belt you must touch the spring.let me know how it goes.
Nov 11, 2008 | Dryers
Zanussi TC7114W condenser Drier
belts do not figure 8
they look something like this
f6516ed.jpg the front panel comes off, to access the drum without removing bearings etc, and the belt can be placed easily, around the drum and motor pulley.
then pull the tensioner hard against its spring, loop the belt around the tensioner and allow the spring to tension the belt.
Feb 14, 2008 | Zanussi TC7114W Electric Dryer
Maytag Atlantis MAV6000 Top Load Washer Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
