Question about Vehicle Parts & Accessories
How to service bmw x1 e84 - Vehicle Parts & Accessories
  • 36 Answers
(a) Take car to BMW dealer and ask for a service. They have the full range of tools and fluids required. or,
(b) Buy a Service Manual and the correct tools and fluids. or,
(c) Search the internet for a Service Manual to download, then buy the correct tools and fluids.
There is no way round this if you want a full and proper service. You can have various degrees of a partial full service either by taking it to a non-BMW garage or by doing it yourself but if you want a proper one then the properly trained staff with the proper gear will (should) do it properly.
Posted on Jan 06, 2015
How to reset run flat warning on bmw x1 2011 model sdrive
Follow these simple steps to reset the BMW TPMS without the iDrive system:
  1. Check all tyre pressures are set to the manufacturer's recommended settings.
  2. Use the indicator stalk to scroll down until you see the tyre symbol and 'RESET'
  3. Press the BC button on the end of the indicator stalk.
  4. The display with show 'RESETTING'
Aug 29, 2016 | 2011 BMW X1 sDrive18d
How to reset oil change light 2012 bmw x1
hold the middle button down and put the ignition on and use the bc button at the side and to reset oil then filter.
Jul 21, 2016 | 2011 BMW X1 xDrive20d
How to reset bmw x1 after oil change?
2010-2015 BMW X1 Service Oil Light Reset: 2010 2015 BMW X1 Service Oil Light Reset
Scroll down page on the above link to 2010-2015 BMW X1 for instructions.
Jul 21, 2016 | BMW Cars & Trucks
Engine cranks when hot. Why doesn't it start?
BMW wont start, electrical problems FIX! - YouTube
? 2:45
https://www.youtube.com/watch?v=L8akXREk80w
Jul 18, 2014 - Uploaded by DeviledDevin
BMW wont start, electrical problems FIX! .... After 6 days of reading and watching DIY videos might just open a service bay for Bimmers. ... the ignition refused to transfer current to engine after few productive cranks leaving me with an unfinished ... Now comes the big question: where can I buy this product?Missing: x1 ‎xdrive20d
Summary of engine cranks but won't start threads (gas air spark ...
www.bimmerfest.com > ... > 5 Series > E39 (1997 - 2003)
Nov 15, 2013 - 25 posts - ‎10 authors
any of which would cause an engine to not start - but - there wasn't a good ... See: How to test compression on a BMW E39 V8 engine (1) and on the I6 engine (1) ... etc., but who don't post codes from an OBD scanner with their question (1) ..... Likewise, if the fuel pump relay had an electrical short or open, ... Hard to start when engine is warm
Mar 29, 2013
X5 sometimes crancks but won't start
Oct 10, 2012
More results from www.bimmerfest.com
Dec 25, 2015 | 2011 BMW X1 xDrive20d
2004 Bmw x5 valve cover torque specs
valve cover gasket torque spec? - Bimmerforums
www.bimmerforums.com/.../showthread.php?...valve-cover...torque-spe...
Dec 7, 2012 - Remember the little rubber grommets around the cover bolts? ... Location: alabama; Posts: 5,537; My Cars: 2002 bmw 325 ... Torque spec for the M52 valve cover bolts is 89 inch-pounds / 7.4 ... 1976 - 1989 (E24) · 2004+ (E63, E64) ... 2012+ X1 (E84) · 2003+ X3 (E83,F25) · 1999+ X5, X6 (E53, E70, E71). Valve Cover Bolt Torque Specs
Oct 25, 2014
Valve cover screw torque specs?
Nov 9, 2012
leaking valve cover gasket
Dec 29, 2011
How specific for torque specs?
Dec 27, 2011
More results from www.bimmerforums.com
Nov 06, 2015 | Cars & Trucks
Explain fault code 2f4e roadspeed for e90 bmw
Search www.utube.com with your question and see if you can find a video ?????
Aug 12, 2014 | E90 E91 E92 E93 E82 E84 E87 E88 Mini Dc...
Where can I find the full service manual for Bmw x1 2011? Brake pad, disc replacement, suspension, steering system alignment and balancing etc... Also how to repair the punctured run flat tyre on Bmw x1???
Take the flat tyre to a tyre shop and have it repaired there as believe or not , puncture repair requires the correct tools and procedure for safety. As for the rest a good workshop manual should have that information or get a service hand book from the dealer service centre.
May 23, 2014 | Cars & Trucks
X1 reset of tyre pressure warning on dashboard
I had a small nail in the near new tyre that BMW service said needs replacing. I took it to my local tyre guy and he fixed it although he said he shouldn't. Happy days!
For X1 you need to turn engine on and use the scroller on the indicator stalk to get the reset indicator, then hold the BC button on the end of the stalk for 5 secs. I had to do it twice but prob solved.
Believe it or not, it's in the owners' manual...
Sep 27, 2012 | 2011 BMW X1
Removing headlights BMW x1
Open your BMW's hood. Locate the black bulb cover for the bulb you need to replace. It is located behind the assembly in the engine compartment.3 Reach down into the compartment and turn the cover to the left to pull it off.4Turn the bulb holder left and pull it out of the assembly.5 Remove the old bulb from the holder. Pull it straight out.6 Insert the replacement bulb into the holder.7 Replace the bulb holder into the assembly and turn it to the right.8Replace the bulb cover and turn it to the right
  • Dec 03, 2011 | 2011 BMW X1
    Vehicle Parts & Accessories Logo
    116 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
