Question about Logitech Z-10 Computer Speakers
Logitech speakers no sound - Logitech Z-10 Computer Speakers
I insstalled logitech SL11 desktop speakers on my XP2000. Now I can't get any games sounds. There is sound on my computer, but nothing from speakers
check do u install sound driver..or check the speaker and woofer cable also check woofer and CPU sound cable this is working
Mar 13, 2012 | Logitech LS11 2 Speakers
No CD and cannot find driver for Logitech R-10 speakers-HELP
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Download the drivers from this link
http://www.logitech.com/index.cfm/downlo...
if you still have a problem try
http://logitech-en-amr.custhelp.com/cgi-...
Hope this helps :)
Sep 15, 2009 | Logitech R-10 Computer Speakers
I have logitech x-120 speakers and cant get any sound out fo them
I have logitech 530 speakers, can only get 2 speakers and sub to work. Just installed new sound card. When I run a test on all speakers they work, till i try to listen to music, then only 3 work
Mar 09, 2009 | Logitech X-530 Computer Speakers
Logitech x-540 speakers wont work??
unplugg your hdmi cable and use a regular monitor cable then plug your speakers in to your sound card
Feb 27, 2009 | Logitech X-540 Computer Speakers
Logitech z-340 speakers
These speakers just plug into your sound output mini-jack. No "speaker" driver is required, just drivers for your sound card. I'll bet those are already installed.
Jan 19, 2009 | Logitech Z-340 Computer Speakers
Logitech x-530 speaker problem
Try going through this troubleshooting procedure site first: http://logitech-en-amr.custhelp.com/cgi-...*uWZ8vi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzgmcF9wcm9kcz04NDQsMTcmcF9jYXRzPSZwX3B2PTIuMTcmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9Mg**&p_li=&p_topview=1 If you get no solution from this, there are other similar logitech speaker systems that have had similar problems on initial models. it appears that logitech have been very helpful with replacing speakers in the past if design or product is faulty. Give them a try. hope this helps:)
Feb 21, 2007 | Logitech X-530 Computer Speakers
Logitech Z-10 Computer Speakers Logo
76 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
