Question about Westinghouse Ovens
Removal of stove top
Cant lift top of stove to clean
3 Suggested Answers
mreid542
  • 166 Answers
SOURCE: 1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Posted on Jul 01, 2010
tbreeze47
  • 3083 Answers
SOURCE: I lost my manual for
If you go to the following webpage you will find a manual that you can get by calling the 800 number:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167385&diagram_id=28331048#d28331048
The site also has great diagrams, in case you ever need them, as well as a schematic.
I tried to find just the self cleaning instructions, but to no avail, so hope this gets you where you need to be.
Also, you could call an Appliance repair shop that services Amana- they could probably tell you over the phone.
Posted on Dec 16, 2010
How do i clean the inside the glass on my oven door
The door usually has about 4 to 8 screws on the inside. Remove the door first by opening it to 45' and lift it off its hinges. Sit it on top of the stove carefully after putting an old towel and a garbage bag on top of it. Remove the screws in the door and the inside will lift off the outside skin. Clean the glass with oven cleaner and reassemble. Ours needs doing too!
Feb 11, 2016 | Ovens
Does stove top lift up for cleaning
sad to say but without the proper information as MAKE /MODEL what else can we do . Absolutely nothing .
Aug 05, 2015 | Ovens
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 | Ovens
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
Cant get oven to turn on. the only thing that works is the stove top n have to light it my self. My electical screen wont turn on which controls my oven
Check and see if the stove is plugged in. I suspect your DSI module has failed.
All these stoves ain't the same nor do they even work on the same principle. I am guessing from the picture you have a DSI system. For a more precise answer always post a mdle number. Most model numbers are posted on the oven frame of the lower drawer.
Here is your DSI service Manual
Dec 21, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Jul 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I just moved into an apartment that has an older Caloric Prestige oven and range and cannot find the Pilot light--Please help
Hi, The caloric ranges use diferent types of pilot igniters, to avoid any further delays, I suggest geting the model number off the stove usually located under the stove's top, you don't need any tools just lift the range top(like when you are going to clean it) the model number is located usually on a metal plate in between the burners, or if it's not there , it will be inside the oven around the door liner or the oven liner. When you do locate the model, just go to the repair clinic.com website and type in the model number, follow instruction after that. see the following figure it might help in locating the model number: small_13_4.jpg
Apr 13, 2010 | Ovens
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
I cant clean my glass on my stove where do i take it apart. i tryed the 3 screws on top put i still cant take it out ( the glass part)
put the door down, and unscrew all the screws inside the oven door. Be prepared for the door to come apart as you come to the last few screws.
Nov 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Aug 01, 2008 | Ovens
Ovens Logo
13 people viewed this question
Top Westinghouse Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Westinghouse Oven Expert? Answer questions, earn points and help others
