Question about Car Audio & Video
I can't find accessories switch toyota hzj75
I a trying to install UHF radio
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
You can take feed from the back of your fuse panel identify which fuse has 12 volt when you turn on the key , or usually easier the cigarette lighter socket is normally switched on with the key splice into the positive wire on this. Negative your set directly to the car chassis make sure you have an inline fuse fitted on your positive to the UHF set at least if get your wiring wrong you won't blow your set..
Posted on May 02, 2014
Where can I get a Circuit Diagram for a Uniden UHF 012sx UHF CB Radio?
The only place you would get that is from Uniden themselves.
UHO12SX Manual - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH012.PDF
UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Features. 2. Preventative Maintenance. 2. Troubleshooting. 2. Controls/Connectors. 3. Missing: diagram ‎012sx
[PDF]UH8060NB - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060NB_OM.pdf Operating the UHF CB Radio in Duplex Mode. 17. Scanning ... The Uniden UH8060NB is designed to provide you with years of trouble ... Built-in AVS Circuitry†.
[PDF]UHO12SX Manual.cdr - Uniden
https://www.uniden.com.au/RESOURCES.../uhO12SX_OM_2yrWarranty-Updated.pd... UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Controls/Connectors. 3. Indicators. 4. Included with your uh012sx. 5. Operation. UHF CB ...Missing: circuit ‎diagram ‎012sx
Circuit Diagram for Uniden UHF 012sx Google Search
Mar 19, 2017 | Uniden Radio Communications
Trouble shooting manual for hzj75 toyota landcruiser
you will find a trouble shooting section in the workshop manual
Feb 07, 2015 | Toyota Cars & Trucks
How do I factory reset a oricome 200rx uhf
Factory reset
If the radio's display locks up or stops functioning properly, you might need to reset your UHF radio. Caution: this procedure clears all the information you have stored in your UHF radio.
Before you reset your UHF radio, try turning it off and on again. If your UHF radio is still not functioning correctly you may need to reset the UHF radio! While holding the F/DPX button, turn the UHF radio on. INITI AL will be displayed for 1 to 2 seconds, the radio will then return to its original display.
Oct 02, 2014 | Radio Communications
Toyota hzj75 wiring diagram
If your car has a standard gear box I would look towards the clutch safety switch.
Apr 24, 2013 | Cars & Trucks
I need a pdf manual for a motorola p10 two way uhf radio
Here it is: The Manual for Motorola Radius P10 Two Way Radio.
Hope this helps!
Remember to Thumb me Up! :D
~~Dayminner
May 30, 2011 | Motorola Radius P10 Two Way Radio.
Uniden uhf 15sx radio how to wire up
Hi,my name is John. The other red wire is positive also, and the black is the negative or ground wire......hope this was helpful....Rate this on the four thumbs-up.....John
Jul 18, 2010 | Uniden Radio Communications
Hard Start Toyota Landcruiser HZJ75
two first things to check fuel and spark ...fuel make sure your fuel pump is working its messy but the easiest way is to pull the fuel line "only one connection" and turn key to on then press gas pedal and gas should pump out if not fuel pump is bad... if thats not it you want to check for spark easiest way is to pull one of the spark plug wires and stick a screwdriver in the end then hold the screwdriver to where the metal shank is approx. 1/4" away from any metal surface ... hold the screwdriver without touching the metal shank!!! have someone crank the engine you should see a spark intermittently between the screwdriver and the metal youre holding it close to.. if thats ok the only other thing i can suggest is get a battery with more cca "cold cranking amps"..hope this helps..OH YA ON A SAFER NOTE!!!...DONT LOOK FOR SPARK WITH THE ENGINE WET WITH FUEL..
Sep 19, 2008 | 2001 Toyota Land Cruiser
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
