Question about Amana ARS9265B Side by Side Refrigerator
Dirty ice My Amana Side by side is leaking water into my ice tray.I noticed all the pile of water it made while leaking had frozen and it was dirty. Real dirty. Looks like muddy water almost? Anyone know what this could be?? I was pretty grossed out by this dirty ice. Someone please help
    Novelist:
  • 131 Answers
Did you change the water filter recently? If so, you may have some air in the lines which can be purged with a few minutes of dispensing water through the front.
Posted on Mar 10, 2008
Amana ptac unit blows air, it feels kind of cool, but it's set at 65 and it's not reaching the desired temp... does it need 2 be recharged or are my lines possibly froze...???
If the unit is frozen you should be able to see ice at the indoor coil. If you pull the air filters and peer inside to the indoor coil there may be ice. Either way it needs service. If no ice and blowing cool not cold it could be the condenser coil is dirty. On the outside you can see the air leaving side of the condenser coil. The air entering side is the side that gets dirty and can only be seen by pulling the unit out of the wall. Its best to leave it in the wall and call a tech that has experience with ptacs.
May 23, 2015 | Amana Heating & Cooling
I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to...
Check for freezer temp - if it is not 10 degrees or below the ice maker thermostat will not turn the ice maker cycle on by removing the frozen ice in tray and then refilling it for next dump cycle. And if freezer temp is high you may have leaking door gasket, dirty condenser coils, improperly operating self defroster which raises temps, low refrigerant.
Aug 04, 2017 | GE Refrigerators
I left tray half full and was gone 3 days, got back and ice maker made a few trays of ice but lever was stuck to the pile of ice, i unstuck it but now it will not make ice
hi there.this sounds like the ice mach is at fault.check leaver if is not jammed on off.try defrosting all and restarting.fill ice tray manually if empty.service condenser unit to rule intermitent defrosting(hence leaver jammed )make sure frezer reaching temperature. hope this helps Ali
Aug 24, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side ice maker tray is full and frozen but cubes aren't being ejected
Make sure the ice crusher/dispenser is working or gt a technician 2 look at it. Also ensure that u do not spil water when refiling the ice maker n do not go beyond the full markings 4 this may cause malfunctions when the water is frozen.
May 05, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Aug 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana SX22se Not kkeping things frozen ice maker not making ice
If both of your fans are working,you will will need to defrost it.
Feb 16, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Leaking water from freezer
take back panel off inside freezer. you will see a drain tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off ice with a hairdryer and follow up with hot water till it flows away freely.
also check the drain tray heater is ok
Oct 13, 2008 | Refrigerators
Ice Tray Won't FIll with Water
number one repair leak could be as simple as loose fitting most likely fitting needs replaced should solve problem if not once the leak is repaired pull out ice tray inside fridge in the rear you will see small outlet that fills the trays run a blow dryer full heat on it to clear it from freeze up which might be clogging your line good luck hope this helps
Sep 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker overfills with water, drips into ice bin, and auger cannot turn because of ice. Can't find any water regulator.
Don't have this model, but could there be a weight sensor for the ice tray that is stuck and possibly frozen in the up position? The weight sensor would normally sense when there is enough water in the ice tray and then cause the water to shut off. See whether the tray should have up and down vertical movement.
Jul 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana ARS9265B Side by Side Refrigerator Logo
138 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
