Error code E000808-0000 IR 2318
The machine displays restart and error cod **E000808-0000
redzventures
  • 149 Answers
SOURCE: IR-2570CI
This error indicates that the patch image read sensor is dirty. You can locate the patch sensor by removing the drum unit from the front of the machine. The patch sensor is located in the machine, directly above the drum unit, halfway intothe machine. If you look into the machine and up you will see a white plastic unit running along the top about halfway point between the front and back of the machine. The patch sensor is inset into that unit and is black plastic. Clean with a lint free cloth several times - as it is hard to see the actual sensor, feel along the strip with your fingers until you can feel the indent where the sensor is - concentrate your cleaning around that area. Now replace the drum and turn the machine back on (I hope you turned it off first).
Removing the drum is easy but hard to explain. In fact, if you get the front cover off, you've done the hardest part. There are some hidden screws, one above the front cover to the left - as if you are looking down on the machine, there may be a small circular plastic cover hidding access to this screw. Remove it and unscrew. If you have an internal finisher, you will have to remove the circular covers above and below the front of it to push your driver through to the hole you need. Sounds complicated but once you've done it you'll see that it's easy when you know where the holes are. There is then another screw at the top, near to right that you access through the panel above - just look around and above the front cover to find the screws. Good luck
Posted on Aug 30, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
  • 159 Answers
SOURCE: CAnon xerox Machine IR 2318
Hello, unfortunately it appears you need to replace the fuser film (probably the upper roll). I wish I had better news. Good luck!!
Posted on Feb 28, 2011
canontech
  • 1219 Answers
SOURCE: when i put my canon
this is error code for main motor failure, you can try to reconnect main motor, look for breakege of gears, reconnect dc controller, or the main motor must be replaced or dc controller, or ...
As you can see that there is a lot of things that can be fault, so call service!!!
Posted on Aug 29, 2011
SOURCE: in my canon photo copier
canon xerox machine imgaronner 2318 Method of restart
Posted on Jan 25, 2013
In my canon xerxo imagerunner IR2420L displays error massege "restart your the machine, if the problem persist call service rep. **E00010-0000" So plz help if u have the solution.
Hi Suvra,
Error code E0010-xxxx indicates that main motor rotation error. Unfortunately, i am not familiar enough with this machine. You should find the main motor location in your copier and check whether it works properly or not.
I found the link to service manual on the web. If you don't mind to spend little money i think the following link will be useful for you. :)
Canon iR 2422 2420 2320 2318 Service Repair Manual Parts Catalog...
Jan 11, 2014 | Office Equipment & Supplies
Ir 2318 canon Error E000808-0000
Restart the machine If the problem precisest rep E000805-0000
Aug 26, 2013 | Office Equipment & Supplies
Canon IR 2318 Copying Problem
My Canon copier IR 2318 has a problem. When it prints, comes out a dirty paper with texts just easy to be rubbed by a finger and disappear! No any error code shown, so what can I do to fix this.
Jun 26, 2012 | Office Equipment & Supplies
Error e000007-0000 for canon ir 2318
Feb 04, 2012 | Office Equipment & Supplies
When i put my canon IR 2318 on, the code E000010-0000 appears; what can I do to move it?
Aug 28, 2011 | Canon imageRUNNER 6000 Copier
Canon ir 2318 shwos "out of toner.I unpacked the
this is the common problem with 2318. u have to take out the developer assembly out and if u are a rep then check the toner shutter in the dev assembly.it some times does not move in accordance with the toner cartridge. u have to align it with cartridge in home position. and be sure to check the toner cartridge sometimes the churner in the cartridge is broken but 90% is the above said
Jun 03, 2011 | Canon Office Equipment & Supplies
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
165 people viewed this question
k24674
jasbo
jasbo
