Question about Scotsman DCE33PA1SC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Stainless Steel
Brand new Scotsman DCE33 ice maker melts ice
I have a brand new scotsman dce33 ice maker with a water filter. It makes beautiful ice, but then it melts away. The unit is draining.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
Why won't Ice maker make ice?
Scotsman Prodigy - bad Ice thickness probe
May 10, 2014 | Prodigy Scotsman CU1526MA-1A Ice Maker...
Scotsman ice machine DCE33
if it's plugged in and you didn't trip a breaker, the switch in the timer has been known to go
Jan 21, 2014 | Kitchen Appliances - Others
Scotsman icemaker dce33 is making ice, but it is melting
Yes it could and also check dump valve it should not let water through during freeze cycle.
Oct 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Melting ice
The bin has most likely failed. Apparently the bin insulation on the DCE33 eventually gets saturated with water and loses it's insulation ability. Consequently the ice melts prematurely. Condensation starts to build up inside the bin because it's not cold enough adding to the problem as the water drips on the new ice inside the bin.
Mine is 5-yrs old and I was told that it's all the life I'll get out of it.
If everything else is workng properly, harvest time, cube size, cold water spray, then a new bin is the unfortunate solution.
Apr 02, 2012 | Scotsman DCE33PA1BC 15in Built-in...
Hello, need wiring diaghram and trouble shooting for sce275a-1d scotsman ice machine.
DCE33 Service pdf
If you have specific qwess fire away. I'm here all week
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 23, 2011 | Scotsman DCE33PA1BC 15in Built-in...
My Scotsman undercounter icemaker is not producing much ice and the little it does produce is watery. How do I fix? The model # is DCE33PA-1WB. Is this model discontinued?
Wow! That the first time I saw one of these! Never even knew they made it under
counter types.Anyway I'll give it a shot,Let's see here It's not producing ice as it should huh? I Googled it for complaints and found this for you,Linda go to
(http://www.retrevo.com) and once you get there type in (Scotsman DCE33)
into site search engine and it'll list service manuals for your model to seek a fix.
It stated how to make maintenence adjustmments ok now good day!
Jan 02, 2011 | Scotsman 15" Luxury Consumer Ice Machine
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
No accumulation of ice
Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
Nov 16, 2008 | Ice Cream Makers
DCE33 Ice Machine
I believe it was the inlet water valve that needed to be replaced, but I got so fed up with the noise and repairs on this machine that I purchased a Whirlpool ice maker. So far, it's been great. It is much more quiet and produces 50 lbs of ice in 12 hours and shuts off until some of it melts. It only produces more ice about four times a day as it melts.
Sep 27, 2008 | Refrigerators
Refrigerators Logo
970 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
john h
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
