Question about Ricoh Aficio Mp 2852 B&w Copier
In ricoh 2852 - reser tray 1 message is displayed. what to do to solve it
  • 86 Answers
SOURCE: I have a ricoh Aficio
Please you must remove the copies from the output tray.
If you don't have copies in the output tray, check for a black lever at the middle of the exit rollers. It can be either stucked or broken.
If you want this lever can be folded inwards.
Good luck and please rate me, thanks.
Posted on Jan 15, 2009
newport74
  • 58 Answers
SOURCE: My Ricoh SPC811dn is displaying a message : Set
Pull the fuser out ....look around inside the fuser cavity I belive on the left lower side as your looking in..... your looking for a sensor that is knocked out of its bracket...... reinstall sensor and fuser and you should be good to go
Posted on Feb 26, 2010
  • 32 Answers
SOURCE: Describe your ricoh aficio 2232c manual copier
just take a air blower and flow the area from where the paper comes out ur internal paper tray sensor is dirty
Posted on Apr 23, 2010
  • 903 Answers
SOURCE: I have a ricoh aficio 220 and it says internal
There is a sensor above the tray where the paper comes out, and that sensor has a long black actuator. Sometimes that actuator gets turned to the side, and this will cause that message to appear.
Reach above the rollers where the paper exits the copier, find the black actuator, and turn it so that it is hanging down over the tray. Once the sensor is reset that message should disappear.
Posted on May 29, 2010
  • 903 Answers
SOURCE: Ricoh SP c222sf is not recognizing that there is
There is a paper detect sensor which sits in the frame of the machine above the paper tray. Pull the paper tray out and make sure this sensor didn't get broken or knocked out of place. (If you have a can of compressed air, shoot some into the sensor to get rid of possible paper dust.)
Posted on Jun 05, 2010
Ricoh Aficio 2852 copier is having depleted toner error after adding new toner
Clear modes- 107 -hold down C button machine will enter service mode, in case it does not, open the right side door and front door then give it a try, it will enter service mode,but the fact is that for a depleted toner error you don't have to fight so hard, don't tamper the SP mode settings you are likely to land into some other problem & things will get complicated further. Install a genuine Ricoh toner and replace the developer along with cleaning of the TD sensor if a non Ricoh or compatible toner has been used previously.
Jun 24, 2014 | Ricoh Aficio Mp 2852 B&w Copier
What does error code 501 tray 1 mean?
www.ricoh-support.com/enduser/downloads/
Jun 15, 2014 | Ricoh Aficio Mp 2852 B&w Copier
I have a ricoh aficio 220 and it says internal tray 1 is full remove the copy on the display
May 04, 2010 | Ricoh Aficio 220 Laser Printer
Ricoh SP c222sf is not recognizing that there is paper in Tray 1 or bypass - tried to rest tray 1 and turn on/off, but the display still shows that there is no paper. What else can I try?
Mar 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Describe your ricoh aficio 2232c manual copier internal tray problem solving Problem display screen says internal tray open cholland@shawu.edu
Jan 22, 2010 | Ricoh Aficio 2232C Color Copier
I need to adjust the color on my Sylvania, model # 6420ff Flat Screen TV. Help
have you tried to call them, because apparently it 's a hard to find manual on the net.
National Customer Service and Sales Center: U.S.A.
(For lighting products only)
General Lighting: 1-800-LIGHTBULB (1-800-544-4828)
Automotive Lighting: 1-800-347-3420
Electronic Control Systems (ECS): 1-800-654-0089
Consumer Products: 1-800-842-7010
Industrial & Commercial: 1-800-255-5042
Special Lamps & Markets: 1-888-677-2627
National Customer Service and Sales Centre: Canada
Industrial & Commercial: 1-800-263-2852
Consumer Products: 1-800-720-2852
Automotive: 1-800-265-2852
Special Lamps & Markets: 1-800-265-2852
Fax (local): 905-673-1012
Fax (long distance): 1-800-667-6772
Jun 20, 2009 | Sylvania Televison & Video
Duplex unavailabe after driver update to 2.02 with mac osx 10.5.7
Problem solved by simply uninstalling and re-installing the driver (with the same procedure as before... bah!)
Jun 04, 2009 | Ricoh Aficio GX3000 All-In-One Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio Mp 2852 B&w Copier Logo
42 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
