Question about Zoom Music
Zoom g2 1u firmware - Zoom Music
How can I mix the sound of the Zoom A2 and the dry sound of the guitar?
the easiest way to mix less effect sound and more natural guitar sound is to reduce the level of the individual effects within the patch selected. The more challenging method would be to go through a splitter box 1st, or any stereo effects box, to split the signal, and then you will have 2 outputs, one dry, one through the Zoom. The 3rd (and simplest ) method would be to place the Zoom in the effects loop of an amp that features a send / return balance adjustment.
Aug 31, 2016 | Zoom Music
Zoom G9.2tt Gituar Effects Console
get ahold of these guys about repair to the unit, I checked through the manual and couldnt find anything of interest
http://www.zoom.co.jp/archive/English_Manual/E_G92tt.pdf
that might help you but doubt it.
Samson Technologies Corp.
45 Gilpin Avenue, Hauppauge, NY 11788
P.O.Box 18016, Hauppauge, NY 11788-8816
Tel: (1) 631-784-2200 Fax: (1) 631-784-2201
http://www.samsontech.com
E-mail: zoom@samsontech.com
if that dont work you can contact zoom directly at info@zoom.co.jp
Aug 11, 2008 | Zoom H4 Handy Recorder
How to perform a factory reset on zoom H4
Hello ! Actually what you do is download the latest firmware from the ZOOM page. Find HANDY H4 (you can Google that) and go to the Download tab. Follow all instructions. Be sure to have new batteries or be plugged in to AC while you reset. I've done it on my H4(I have 2) and H4n and it worked fine. Be patient, it takes a while once you start. Good luck !!
Mar 09, 2014 | Zoom H4 Handy Recorder
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
Is there any way to reset the H4 back to factory settings? I adjusted levels and everythings out of whack now.
Hello.
Do you havce the manual to the H4? If not, I will provide you with a link to the PDF manual online. In thoroughly scanning thfe manual, there is no general reset function (in the manual, that is). It would be advised to call Zoom (who are very easy to work with) and ask them if there is a factory reset procedure which is not in the manual.
The manual for the H4 is very comprehensive, and there are default settings for many areas of the recorder. You could use this manual to reset your adjustments manually.
Here is the link to the manual:
http://www.samsontech.com/products/relatedDocs/H4_manual.pdf
Thanks for using FixYa
Aug 15, 2009 | Zoom H4 Handy Recorder
Zoom H4 does not power up on battery power.
Probably two years too late, but I recently got a used H4 and it was having this same issue. Upon reading the documentation, it seemed as though it required a specific type of AA batteries. If you update the firmware (mine was 1.3) to the latest version (currently 2.4), you can toggle the battery type under the menu (most likely alkaline is what you want). It also added lots of other great features!
Jun 02, 2009 | Zoom H4 Handy Recorder
Can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4  firmware from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
Nov 18, 2008 | Zoom H4 Handy Recorder
Music Logo
62 people viewed this question
Top Zoom Music Experts
Barry Webster
Level 1 Expert
patonplace
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
