Question about Rolex Watches
Proper size of spring bar replacements
What size would replacement spring bars be for a Rolex GMT 16710 model with holes in lugs?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 210 Answers
.125
Posted on Sep 03, 2014
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: i want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Regards
Arthur
Posted on Dec 17, 2008
SOURCE: Hi, I've got a broken
Two of the spring-bars broke on the clasp of my PRS200, so I took it to an un-named watch repair shop that was closer than the Tissot-authorized store (Leslie Gold Watch Co.) at which I bought the item 5 years prior. After the repair, the clasp kept popping off, so I took it to the Tissot store, and they told me that it was because the ends of the bars didn't fit properly. They replaced the faulty bars for me at no cost, and the watch has been sitting on my wrist fine for the last year-and-a-half.
Posted on Feb 18, 2011
How do I take the leather strap off my bensherman wristwatch?
Depending on the model, if it is one that has a leather strap, then they are held in place with spring-bars that go through the ends of the band protruding out of each end. the points then insert into holes in the bezel lugs and thus hold the band in place.
The best method is using a tool made for this which you can pickup at any Harbor Fright Tools store if there is one in your area. Alternatively, use a small screwdriver and insert it against the inside of the lug where the band rides against. As you begin to pry downward away from the lug, you will see the spring-bar. Look for any ridges on the bar that can be used to pry further... it's really trial and error and use caution to not damage your band. another way that works quite well is a not-too-sharp knife. Again insert it between the band edge and the inside of the case lug and with pressure against the pin, pry downward away from the lug... the ping should disengage
Dec 05, 2014 | Watches
I have a GC G36001L1 and the pin that connects the band to the bezel ust broke. Is there a replacement for this?
Solange - have you contacted Guess customer service? They may repair/replace the watch or watch part for a minimal (or no) charge.
Toll Free: 1-877-44-GUESS (48377).
Monday through Friday 6:00 a.m. - 5:00 p.m., Saturday 7 a.m. - 4 p.m. (PT)
Regards,
DIYpro
Jun 10, 2011 | Guess Gc Collection Diver Chic G36001L1...
My Nixon Rotolog Leather watch broke at where the leather meets the watch. The bar keeping it together broke. I need a new bar in order to keep the watch together.
This is called spring bar or spring pin. You can buy these on ebay. Make sure you get the right size. The distance between watch lugs is the right size. Measurement must be taken in mm.
May 18, 2011 | Nixon Rotolog Leather Watch
Where are the model number and serial number on a rolex
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    Unclear as to how you adjust the rubber band strap
    1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
    2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
    3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
    How to remove a Rolex jubilee bracelet
    if its a real rolex, take it to a store dont play around with perfection. but the way a rolex bracelet is held on is by spring bars. look at the back of the watch and put a small screw driver in the lots and push down on the spring bar. then start to ease the bracelet out, now dow the same on the other side the end should come out
    Oct 06, 2009 | Rolex Datejust SS
    Changing a Rolex metal watchband to a leather watchband
    Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
    Then repeat the same at the other end of the band.
    Measure the distance between watch case lugs- this will be exact size for your new leather band.
    Rate me, plesae.
    Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
    Buy and replace new watch band ?
    I just replaced the band on a women's ironman watch, so I know it is tricky, but can be done. First remove the old band using a small flat blade screwdriver and determine that the spring bars that came with the new band are the right size by comparing with the old ones. My new ones were too large. Then, use a pen to make marks on the back of the watch case in alignment with the spring pin holes . Put a spring pin into the band and position the band on the watch the way it will be attached, with the pin just above the marks. Use the small flat blade screwdriver to insert one of the spring bars into its hole and align the other side of the spring bar with its mark on the case. Compress the spring bar and slide it down until it roughly aligns with its hole, then, push the band sideways toward the hole and wiggle the band until the pin seats. Apparently the hole alignment is very tight and, without that last step, the pin simply will not seat. After spending a lot of time with the first strap, locating the spring pin hole by trial and error, I used a magnifying light for the second strap to allow me to see the spring bar hole, making the process a lot faster.
    Mar 13, 2009 | Timex Sports Ironman Triathlon 100-Lap...
    I want to adjust the steel bracelet on my new GMT II
    Regards
    Arthur
    Dec 13, 2008 | Rolex Watches
    How to adjust leather rolex watch band
    On the clasp of the watch. There are small holes ware the spring bar sits.
    More current models do not have holes that go all the way through on the buckle but the spring bar still sits in between. With a small screw driver press in tward the middle of the strap ware the spring bar sits at the end of the leather strap. Pop out the strap and the spring bar and then place it into the slot that fits.
    Oct 14, 2008 | Rolex Day-Date President 118238 Wristwatch
    Watches Logo
    41 people viewed this question
    Top Rolex Watches Experts
    Samyfam
    Samyfam
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
