Question about Vehicle Parts & Accessories
Heater core removal
I have a 2006 a6 s-line 3.2l. how to change the heater core? does the dash have to come out or can it be replaced without removal?
    Problem Solver:
  • 35 Answers
Clear a wide path for taking the unit out. Is a terrible thing when wiring gets damaged due to not being able to see whats going on.
Posted on Apr 19, 2014
Can I change heater core in 1989 s10 2.5 no air without taking dash out
The dash does not have to be removed for heater core replacement. Remove any paneling for heater box access and remove box assembly and change core. Flat rate time at a shop is about 1.9 hours to complete this repair
Jan 04, 2016 | Cars & Trucks
2006 500. How can I remove the heater core without removing the whole dash?
You didn't mention what type of vehicle your referring to but in almost every car these days you must remove the dash.
Jun 07, 2015 | Ford Cars & Trucks
Manual 2006 chevy cobolt heater core
any good mechanic can change the heater core .
Mar 20, 2015 | 2006 Chevrolet Chevrolet Cobalt LS
How do you replace the heater core
Most heater cores are located below the dash board on the passenger side, it does involve a lot of labor for the most part. In rare cases the dash has to be totally removed, but most heater cores can be removed by removing plastic panels or covers underneath the passenger side dash board. Mind you that there's a lot of bolts and fastners to be removed and wire harnesses to disconnect just to reach the heater core. Then you have to remove 2 heater hoses in the engine compartment other wise the heater core will not come out from underneath the dash board. You also have to remove the glove compartment to have easier access to the air ducts you have to remove, takes quite a while if you don't know what you are doing.
I just replaced the heater core on my Oldsmobile and it took me several hours just to undo all the ducts, bolts and fastners to get to the heater core, the labor involved is what gives you trouble most of the time.
Mar 05, 2015 | Haynes Hyundai Sante Fe Repair Manual...
How to replace a 1995 Audi A6 heater core?
need to remove dashboard, all things on it must be remove to have the full access to the heater core. partly it is made of aluminum. and find holder to be remove so the entire heater core can be remove.
Dec 30, 2010 | 1995 Audi A6
Rear heater core water lines leaking
You will have to change it out!
If it is necessary to remove the heater assembly, the cooling system must be drained before removing the heater core.
When a heater core leaks, a new heater core is installed or the old one repaired.
Heater Housing
  • The heater housing is usually under the dash and must be removed to gain access to the heater core.
  • Procedures for replacing the heater core vary with the year, make, and model of car. It threfore necessary to consult the manufacturer's repair manuals for the proper procedure for replacement.
f74-01.gif The heater housing is disassembled to get to the heater core.
Heater Core
  • Remove the access panels(s) or the split heater/air conditioning case to gain acess to the heater core.
  • Remove the heater coolant hoses.
  • Remove the cable and/or vacuum control lines (if equipped).
  • Remove the heater core securing brackets and/or clamps.
  • Lift the core from the case. Do not use force. Take care not to damage the fins of the heater core when removing.
  • To reinstall the heater core, reverse the removal steps.
When the heater core leaks and must be repaired or replaced, it is a very difficult and time-consuming job primarily because of the core's location deep within the firewall of the car. For this reason always leak test a replacement heater core before installation.
Dec 24, 2010 | 2000 Ford Expedition
Can I get to the Heater Core without going through the engine. (Maybe the side wall?)
Inspect/Replace If it is necessary to remove the heater assembly, the cooling system must be drained before removing the heater core.
Heater Housing
f74-01.gif The heater housing is disassembled to get to the heater core. Heater Core
Nov 18, 2010 | 1983 Buick LeSabre
How to get to the heater core in a 2006 mazda 3? had a snake get lose in the car an i think it got to the heater core to keep warm but it died an its stilll in my car i need to know where it would might...
heater core is usually on passenger side under the dash lift your hood and look for two lines going into your firewall and that will give you an idea exactly where it is inside your vehicle. it is complicated to get at might involve removing dash
Jan 10, 2010 | 2006 Mazda 3
Heater Core replacement
yes you do have to disconect the a/c system.google dash removal for jeep.hope this helps
Oct 04, 2009 | 2000 Jeep Grand Cherokee
Heater Box Removal To Replace Heater Core
heater box comes out via the eng side of the fire wall there are a couple of screws but not sure were should be no need to pull dash out
Oct 04, 2008 | 1995 Audi A6
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
