Linux Data Recovery
I have lost my all data from Ext2 and Ext3 partitions. Can you pleas help me to it back?
Linux Data Recovery issues
This recovery tool completely supported linux EXT2, EXT3 and ReiserFS file systems. Recover linux data from linux hard drive in any physical & logical data lost situations.
Try:- Linux Data Recovery Tool
May 09, 2014 | Computers & Internet
Linux Data Recovery Issues.
Hi Rosu,
I have this site for you in order for you to reformat your PC including image. Hope it helps.
How to recover partitions and data using Linux Tutorial
May 02, 2014 | Computers & Internet
My usb delete every thing and i for got my password
How did your usb delete everything only a person operating a computer can delete.
And what password did you forget ?
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
http://www.downloadcollection.com/ie_asterisk_password_uncover.htm
IE Asterisk Password Uncover allows you to view passwords hidden with asterisks in password fields in web pages and ActiveX controls.
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
http://www.snapfiles.com/freeware/system/fwdatarecovery.HTML
http://www.cgsecurity.org/wiki/TestDisk
TestDisk is a powerful open-source tool for recovering your data.
Not only can TestDisk perform basic file recovery like undeleting accidentally deleted files from FAT, NTFS, and ext2 file systems, but it comes with a host of additional functionality.
With TestDisk you can recover your boot sector from a backup, rebuild your boot sector, fix FAT tables, fix your MFT, locate the ext2/ext3 backup SuperBlock, copy deleted files from partitions to recovery media, and find lost partitions in dozens of formats to help you locate your lost data.
MiniTool Power Data Recovery
(Free Edition) is my top pick as it proved to be way ahead of the competition.
It comes with a very intuitive interface which is suitable for all users.
It has recovered 1GB in 85 seconds and managed to recover all 106 files after the disk was formatted.
Help files are very good explaining most of the recovery methods step by step. A must have for any computer.
Mar 17, 2014 | Computers & Internet
I have downloaded Ubuntu Linux 12.04 and am running it under wondows xp sp1. How can I delete windows and just run Ubuntu ?
Here is what you need to do:
1. Open 'GParted'. From the menus: System -> Administration -> GParted
2. Right click on the ntfs partition and select 'delete'
3. Right click on this deleted partition and select 'Format to' and select ext3. This should accomplish what you want.
If GParted is not installed, then open a terminal window and type
Code:
sudo apt-get install gparted
And then proceed with steps 1-3 specified above.
PS: Backup any data you need from the WinXP partition before you do this.Alternately, instead of formatting the XP partition to ext3, you could do this:
Using gparted, as described above:
Right click the XP partition and click delete.
Right click the Ubuntu partition and click resize
In the resize dialogue, change the settings to that it is as big as possible.
Click apply changes.
This is riskyer, so BACK UP EVERYTHING!!!!!! I do not take responsibility for lost data.
This however will be closer to "unpartitioning" the drive, what was suggested above will still result in it being split into two partitions, they will just both be linux partitions.
Oct 27, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Did a full recovery on windows xp home edition.
Freeware for data recovery Best freeware for data recoveryWhen computer data loss happens, like deletion, careless format, it actually means losing data. Data recovery is generally means a consumption of time and money. Ever through there are lots of freeware for data recovery, most of the freeware can only recover deleted files. These freeware for data recovery are can do nothing when the data is lost due to format, partition loss, system crash.
Luckily, EASEUS launched the first full-featured freeware for data recovery: EASEUS Data Recovery Wizard Free Edition. This freeware for data recovery is designed to recover data from all kinds of data loss problems. This data recovery freeware is so potent that most commercial data recovery software can't do more than it. It is able to recover data from lost or deleted partitions and even recover your files after partitioning or crashed hard drives. The freeware works well with FAT12, FAT16, FAT32, NTFS/NTFS5 and EXT2/EXT3 file system.
How to use freeware for data recoverymain.gifThis freeware for data recovery is very easy to use. A wizard interface will guide you through the whole process of data recovery. There are three recovery modules on the main window of the freeware.
Deleted File Recovery: aims to recover deleted files even if emptied from Recycle Bin.
Complete Recovery: aims to recover lost files after format, or from RAW partition.
Partition Recovery: aims to recover lost file from lost/deleting/missing partitions or system crashes.
Takes complete recovery for example:
1. Click the "Complete Recovery" button on the main window of the data recovery freeware.
2. Choose the partition that was formatted and click "NEXT" to start searching on this partition.
free-complete-recovery-1.gif3. Press "NEXT" button. The freeware for data recovery will launch the "Building directory" procedure to searching the files. You will see file/folder tree very soon.
free-complete-recovery-5.gif4. After the lost files are found on this freeware for data recovery, you can preview it to check the file quality. Select the files you want recover to save them to a safe place.
free-complete-recovery-6.gif5. The lost files are back to your hard disk now.
The freeware for data recovery is the easiest and most powerful freeware for data recovery. Why not have a try, you have nothing to lose.
Check it out
Jul 28, 2010 | HP Compaq Presario SR1303wm PC Desktop
How do you do system recovery for linux?
try the ubuntu site. there should be a fix there in the forums
also I found this list on tech republic:
1: Knoppix
[UPDATE: New link] Knoppix is one of the better tools for rescuing data from sick machines. It’s a full-blown live Linux distribution with a strong, user-friendly GUI that will allow you to easily mount a drive and then copy the data (which you will locate in an easy-to-use file manager) to an external source. Of course, Knoppix comes with the full arsenal of Linux commands, which place just about everything you need at your fingertips.
2: Trinity Rescue Kit
Trinity Rescue Kit might leave you wondering, “Why isn’t this tool being developed faster and on a larger scale? Although TRK is rather slow to develop, what it offers is just short of amazing. Place it on a USB drive, boot your virus-laden machine, and scan the mounted drives with clamav, antivir, bitdefender, and more. This tool is all command line, so you might have to bone up on your commands to really make use of it.
3: Avira AntiVir
Avira AntiVir is a command-line antivirus tool that is fast, robust, and dependable. There is a GUI tool, but installing it is almost more trouble than it’s worth. (It requires Java.) Installing AntiVir on Linux isn’t the easiest of tasks, but it’s certainly no kernel compilation.
4: GParted Live
GParted Live is a live Linux distribution that allows you to manipulate partitions on a drive. It supports numerous file systems and lets you can resize, create, and delete, partitions. You can run GParted Live from a CD or a USB drive, so it’s very portable.
5: SystemRescueCd
SystemRescueCd is another live Linux rescue CD that offers numerous tools to handle numerous tasks, including partition manipulation, file recovery, hard disk testing, ftp, and disk formatting. As with most live Linux distributions, you can place SystemRescueCd on either or CD or USB drive, and it offers an easy-to-use GUI and plenty of tools.
6: Ubuntu Rescue Remix
Ubuntu Rescue Remix is quickly becoming one of my favorite data recovery tools. Like all good live Linux CD tools, it includes an outstanding GUI (it is Ubuntu after all) that can help you handle tasks other tools can’t handle. You can recover and rescue Mac files/filesystems, recover data from nonstandard external drives, recover deleted files, and more. The one thing URR is missing is antivirus tools. But, since this is a Linux rescue disc, once installed, you can simply add the tools you need to your USB live CD.
7: F-Secure Rescue CD
F-Secure Rescue CD is based on Knoppix and allows you to check the integrity of your installed applications. It also allows advanced data repair and recovery, as well as recovery from that ever-dreaded malware!
8: Ddrescue
Ddrescue is a Linux tool designed to copy data from one file block device to another. This tool will aid you in rescuing data when your drive is suffering from read errors. Unlike many of the tools on this list, Ddrescue is not a live distribution but a tool you will use on a running Linux machine. So to rescue data, you will have to attach that troubled disk to the working Linux machine.
9: Safecopy
Safecopy is similar to ddrescue, allowing you to copy files from a disk suffering from I/O errors. It also includes a tool that allows you to read data from CDs in raw mode, as well as issue device resets and simulate bad media for testing and benchmarking.
10: Linux rescue mode
This is the only entry on the list that isn’t a downloadable tool. Linux rescue mode is a mode booted with the help of a Linux boot CD, allowing you to repair a broken system. From rescue mode, you can recover a root password, repair or reinstall the boot loader, and more. When you boot into rescue mode, it will typically mount your installed system into /mnt/sysimage, where you can take care of any business necessary.
More rescue tools?
These 10 Linux tools can help you recover, rescue, and repair a Linux, Windows, or Mac machine. Of course, plenty more tools are out there. Have you come across a Linux tool that can help you repair or recover a damaged or sick drive? If so, share it with your fellow TechRepublic members.
Apr 26, 2010 | Belkin (F5D5231-4) Router
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
