Question about Epson TM-H60000II Thermal Printer
The printer does not take the paper
The printer does not take the sales slip
My Dell 924 CLAIMS it has a paper Jam and does NOT.... it will not clear this out and I can't print anything! Help!
check the feed rollers for a dirt build up , they can be cleaned with a damp cloth, the probable cause is slipping feed, the printer expects paper and none is fed due to the slipping of the rollers.
look where the front edge of the paper sits, there are rollers there that bring the paper into the printer, clean them.
Jan 11, 2011 | Dell 924 All-in-One InkJet Printer
Will not print evenly on cardstock business cards
This can be caused by the cardstock slipping to one side as it prints. Make sure when you print you are using the card stock settings found under your printer setup - paper type. Check to make sure that the paper you are usng is meant for your printer, most printers are meant for up to a certain pound of paper eg 120lbs. and going over this could mean that the paper is too heavy for your printer which causes the rollers to slip as it pulls the paper through your printer.
May 30, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
4x6 glossy postcards feed through slipping
Make sure that the paper meets the specifications for use in your printer.
The paper you are trying to use may be to heavy to be moved correctly through the paper path.
Don
Feb 25, 2010 | HP LaserJet 4200 Printer
When printing should paper be fed from back of machine or from below? Currently paper is being fed from behind without black ink
It makes no difference which tray you feed from, it's a matter of personal preference, if black is not working, you probably need a new printhead, QY6-0049-000. The black is always the first to wear out on a printhead.
Dec 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper feeding in crooked
Check that all of the sliders in the feeder tray are snug against the paper. Sometimes they tend to slip out and allow the paper to wiggle in the tray resulting in a crooked feed. Other possibilities are dust buildup on the rollers, or worn rollers causing the paper to slip on its way through the printer.
Jul 17, 2009 | Lexmark X4550 Multifunction Wireless Color...
Top rollers on Dell 1710n won't pick up paper
clean or repalce the pickup rollers, there's either too much paper dust on them causing them to slip on the paper, or there's not enough tred on them like a tire again, causing them to slip, and be sure that you aren't overfilling the tray
Jan 13, 2009 | Dell 1710n Laser Printer
HP LaserJet wont pick up paper
Try cleaning the feed roller. It may have debris on it, making it slip. Use alcohol on a lint free cloth. Often you'll see on the paper where the roller slipped on the paper. There may be a dark smudge where the roller slipped. Check it out.
Dec 29, 2008 | HP LaserJet 1200 Printer
My cash register is not printing.
Hi.
If it is a thermal printer, make sure you have the paper coming from the bottom of the roll, not the top. If you have the paper the wrong way around, it will come out blank.
If this is not the problem, please let me know the model number and any other information you can give.
Mark
Dec 08, 2008 | Casio Parts Cash Register PC Desktop
FAX
first off you have 1 year warranty from brother from date of sale and must show sales slip next try and feed a piece of card stock through the adf manualy u may have some thing blocking the paper path
Oct 10, 2008 | Brother MFC-465CN InkJet Printer
Paper feeder
You probably is working with paper excessively wet. Even when you cannot detect the moiture can be present in the paper. Try to use a paper dryer (there are for sale in computers stores). Dont use to leave the sheets in the printer when you are not printing, leave them in the dryer.
May 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson TM-H60000II Thermal Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
