MasterReset lets Nextel Customer Service reset your service in the event of a security or provisioning problem. Reset Defaults - Reset Settings returns all settings to their original defaults; Reset All returns all settings to their original defaults and erases all stored lists. Use only under the direction of Nextel Customer Service...
Hi, You can get the unlock code for a Motorola i576 from www.superunlockcodes.com/motorola-i576/rs16wp9/ at affordable cost. ================================= UNLOCKING STEPS FOR MOTOROLA i576 ================================= 1 - Switch ON your Motorola i576 with a NOT ACCEPTED SIM Card, 2 - Phone will display "Enter Special Code", 3 - You can now enter the Unlock Code.
Hey you can unlock your Motorola i576 using the codes.I found an unlocking service at Unlocking4u.com ..They offer the service for mobiles at cheap price. If you need get it from this provider.
hi,press youer menu bar then you move to messages and after opening it you look at the upper part of your screen,if you see anything like abc that is its on tghe normal mode,but if you see anything like itap on the screen then you have to press down the pound or star key for about three seconds for it to change to the abc mode.you might have to press this down for either twice or thrice because you have other modes on the mobile so you have to keep pressing iot until itb gets to the abc mode.thanks.
Make sure the battery is good in your H700.Make sure your Bluetooth is enabled on your i576.
To do this, go to
Contacts>More>Bluetooth>Setup>Power> then select On.
Back up one level and select Link To Devices.
If everything is correct, they will find each other.
