Question about HP Pavilion dv6000t Notebook
Pavilion dv6000 when power button is pressed,
Pavilion dv6000 when power button is pressed, lights turn blue for a second and then turn off, I cannot power up my laptop, I have not used it in a couple of weeks and left it with the charge cord plugged in to it, and the last time I used it i had no problems, now nothing??
  • 4 more comments
  • dreehme Jun 19, 2009
    i have tried powering up with the power cable connected yes, the charging indicator light lights up for 10 sconds or so then goes off, could the adaptor be bad and therefore the battery died also ?
    should i also unplug the charger ? i have also been trying to find out if my laptop works with just the charger and not the battery, do you know ?? I ask becasue when i unplug the battery and attempt to turn on the laptop with just the charger plugged in I get the same results, nothing.
    ok i will try, i do not have a multimeter.
    that did not work
    so you do not think it is anything major ? or you are not positive as of yet ?
  • dreehme Jun 30, 2009
    i tryed a new battery and my laptop will still not start up ?
  • 281 Answers
Have you tried to boot the laptop with the power cable connected? Is the charging indicator on when you connect it to the adapter? If the charging indicator does not light up, check if your adapter output and try booting it with the power cable connected.
Posted on Jun 19, 2009
  • 2 more comments
  • Arun John
    Arun John Jun 19, 2009
    If the charging indicator shows up for ten secs it is fine. Remove the battery from the laptop and put it back after ten mins and turn on again.
  • Arun John
    Please try what I suggested and get back. I have never tried turning it on without a battery, so I am actually not sure about it. And I have power down here right now so I cannot check it at the moment. I shall let you know as soon as power restores. Do you have a multimeter?
  • Arun John
    Then you will need to get the battery checked.
  • Arun John
    Arun John Jul 04, 2009
    So definitely the problem is with the motherboard. It's better you entrust the service with some qualified service personnel.
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem SCREEN WONT TURN ON LED LIGHTS OF POWER BUTTON...
The dv6000 series was commonly affected by the video card heating up and reseating itself. This was usually a soldering issue. You have a few options, You can either replace the motherboard, or have the motherboard reflowed. Unfortunately the video card itself is not detachable or individually replaceable.
I personally would recommend the second option as purchasing another dv6000 board will likely end you up in the same situation a year or 2 later.
A repair / reflow services on ebay
Dv6000 Repair
This repair tech only does amd processor models, Not intel.
Hope this helps.
Aug 29, 2011 | HP Pavilion dv6000z Notebook
Trying to get my hp pavilion dv6000 to come on.The blue lights come on,but screen is blank.then after about 10-15 seconds it restarts.I have tried to get to bios and can't.I have also took out the...
just turn on keep hitting the f9 key and let it run the hardware test and check if there is any hardware failure
-and then try f 8 while restart and then try last know good configuration
Reply
May 22, 2011 | HP Pavilion dv6000t Notebook
My hp pavilion dv6000 touch pad locked up, it no longer responds.
Try pressing the button above the touchpad to make the light blue, that should re-enable the touchpad again.
Regards.
Jan 13, 2011 | HP Computers & Internet
MY hp pavillon dv6000 won't turn on. I press the power button and the blue lights turn on but they turn off at the same second,not even the fan turns on. PLEASE HELP !!!!!!!!!!!!!!!!!!!!!!
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 turns onn and off
I had a similar problem with my pavilion. They have a cooling fan design that allows for lint buildup and subsequent overheating. You could try using a compressed air and blowing out the exhaust vent area for the fans.
May 27, 2010 | HP Pavilion dv6000t Notebook
HP dv6000 laptop will not power up
the motherboard has a defective power mosfet on the bottom of the MB beside on the power connector.
Jul 27, 2009 | HP Pavilion dv6119us Notebook
AUTO SHUT OFF HP DV6000
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Oct 02, 2008 | HP Pavilion dv6000z Notebook
HP 6227 BLANK SCREEN
LINK
The HP DV6000 has problems that HP is aware of. Check to see if yours is eligible for free extended repair.
May 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000t Notebook Logo
465 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
