Question about Sony DAV-C450 System
Disc tray wont open
Can not open disc tray.
    Novelist:
  • 206 Answers
Get a paper clip and look at the face of the drive.. There is a small hole, insert the unfolded paper clip in the hole and the drive will release. Good luck
Posted on Apr 18, 2014
My disc/dvd tray will not open
find the little hole under the tray and gently push in with a unbent paper clip
Feb 22, 2015 | Gateway Computers & Internet
Sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
May 14, 2012 | Sony SLV-D350P DVD Player/VCR
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
It wont read my disc it sits there and doesnt attempt to read any disc it says open tray how can i fix this?
Ahhhhhh This is a fun one! Ok here is the first thing you should do. Put a disk in the tray and keep in mind the position it is facing. Close the tray and wait for your system to say open tray now open the tray and examine the disc. Let me know if it is in the same position and we'll go from there!
Mar 14, 2010 | Microsoft Xbox 360 Console
Loose disc tray
well, when you opened the tray with a paperclip, it probably jacked up the reading system. The you pushed it in manually. This will totally ruin the system. Try contacting Microsoft.
Jan 16, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
Tray wont open
Power your unit off using the button. when it's off unplug the power source from the back of the XBOX and leave it out for 30 sec. Reconnect the power source and reboot your machine. Try the disc tray again. If it doesn't work try giving it a tap or a solid knock on the top of the case above the disc tray while it's trying to open. Don't drop the machine or try to pry the tray open. If it doesn't open when you tap it then try light pressure on the front of the tray while it's trying to open. (you can tell it's trying to open because the disc status on the screen will say opening...)
Now if the above did not work
Get a straightened paper clip.
Remove the faceplate carefully starting from the indention that you will see on the side
After removing the faceplate, look for a pinhole just below the disc tray.
*There are two pinholes just below the cover of the disc tray and one pinhole below the X and B of XBOX logo.
*You can try any of the three holes
*Pinholes are so small that the girth of the paper clip is the only object that can fit through the pinhole.
Now insert the paper clip into the pinhole then put a little pressure until the disc opens.
If it opens try to close it, if it closes try opening it again, if it wont open the second time then it need to be serviced
If it opens try to close it, if it wont close try nudging the disc to the right and then to the left, if nudging doesnt then it need service
If it wont open after trying all three pinholes - its needs service
It may be jammed or the drive gear stripped.
CALL XBOX CUSTOMER SUPPORT 1-800-FORMYXBOX
If that doesn't work . call Microsoft and they will instruct you on warranty work.
Nov 24, 2009 | Microsoft Xbox 360 Console
The Disc Tray won't open!
press the button the it might go on if not take it back to the shop and say the disk tray wont open lol]
Jan 25, 2009 | Microsoft Xbox Console
Tray wont open
well, my bros does that as well. and i just push on the disc tray a little, like push it up if the console is laying down.. it also could mean the motor that pushes the disc tray is off or disfunctional.
Aug 04, 2008 | Microsoft Xbox 360 Console
Sony DAV-C450 System Logo
161 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
