Question about Canon i860 InkJet Photo Printer
My brother j280 shows little or small amount of yellow on testing
  • 503 Answers
I Would suggest that you check the ink and see how much you still have. If you have lots then i would try running it through the cleaning program and see if this helps it at all. Also If you do get it to work normally, you should be aware that inkjet printers need to be used weekly . If you let them sit to ling then the ink on the jets dries out, and and can clog up the jets to the point that the printer is useless.
Posted on Apr 18, 2014
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
I have a severe shadow on the screen in all colors.
Hey there,
Your issue is related to the small chip inside the Tv, I believe they are called the light engine. It is a small plastic frame with what looks like a graduated glass pane in the middle. Over time this begins to show its age and amount of use by casting the shadow to which you refer. For some it appears as yellowing in spots. It is replaceable but should only be done by those with the right skill and tools. Maybe double the cost of the lamp or a little more depending on Brand.
Oct 03, 2013 | Sony KP-51WS510 51" Rear Projection...
Have two Brother DCP-145C printers and use compatible inks. Now the yellow won't print in either machine. Despite trying cleaning cycles and replacing the yellow cartridges, the test print will not show...
100% you need to replace the print head,in the future use only original cartrige brother not refill or compatible cartridge.If you want to replace the print head you need to take care is difficult to change the print head,you must to unzip the all printer.If a have been useful please give me a vote.
Mar 22, 2011 | Brother DCP 130C All-In-One InkJet Printer
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
Color mismatch
This is kind of hard to diagnose with just what you list. However there are a few things you can do to test it further.
What I usually do is open up Microsoft paint (start-all programs-accessories- the click on paint)
Then make a small box and print the 3 primary colors plus black (red, blue, yellow) see if all three colors print. My guess is only one will print (blue) if this is the case then the ink cartridge is most likely dried up or defective. Also if you have not printed something in a very long time this can also cause the cartridge to dry up. Again this is based on a guess that I think your cartridge might be dried up. However it can be a number of other items.
Also some printers have there own test pages you can run that can also tell you what colors are working and what colors are not.
Thanks again
Hope this helps you out a little bit.
Steven.
Apr 21, 2010 | Brother MFC-5840CN All-In-One InkJet...
Brother 2040 yellow toner light on & won't print. Toner just replaced 8 weeks ago. Printer purchased 6 months ago.
You have a one year warranty with Brother if you need repair. You might shake the toner, or put a small electrical tape over the little round windows on the toner cart. to use the rest of the toner, and press the go button 3 times to print the report that tells you how many prints you've made, you could just be out of toner again...
Feb 03, 2010 | Brother HL-2040 Laser Printer
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
My Brother MFC 210 C printer will not print in yellow.
i cannot print the documents that i want ,,the printer cannot recieved the documents but it can copy.
Feb 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon i860 InkJet Photo Printer Logo
old marine
old marine
