Question about Vehicle Parts & Accessories
What fuel should be used in a 2001 BMW 318i station wagon (touring), 91oct or 95oct, it is not a particularly powerful or high performing engine (1895cc)
  • 503 Answers
I would suggest you check your owners manual and see what fuel octane rating they recommend. You could also try the dealership. My own OPINION is that the better the octane the better the run. Other then that think in the final decision, it's up to you and your wallet.
Posted on Apr 18, 2014
    Scholar:
  • 86 Answers
If you are in the US, the highest octane you will find is either 91 or 92 which will be fine for your BMW. Unfortunately, BMW specifies premium fuel in all their vehicles and we have found it gives slightly better gas mileage, although not enough to offset the extra cost per gallon. You can experiment with a tank of premium and then fill with mid-grade (89) then premium and alternate back and forth and see if there is any difference. The anti-knock sensors will usually offset any lower octane issue and the one or two octane points should not be an issue. You can experiment as you wish. If you either hear knocking or have reduced performance, simply top off with premium and continue to use it.
Posted on Jun 01, 2014
  • 430 Answers
91 should be fine thats what is recommended for my 00 BMW E46
Posted on May 03, 2014
Whilst driving my e46, M43 engine, 318i, 2001 year model, my car picked up a miss and it stopped idling. It also had no power as the engine sounded roudy when i reved the engine. What happened?
Did you replace the spark plugs with the same brand recommended by ? Might also what to go over all the wiring harnesses, you disconnected when replacing the exhaust. Might of pinched a wire.
Sep 03, 2016 | 2001 BMW 318i
How do you fix a loss of power in the engine
how many km /miles on the engine
cylinder compression / valves /02 sensors/ engine ECU
injectors/ fuel filter/ fuel pump
spark /coil packs
Jun 01, 2016 | 2001 BMW 318i Automatic
Why bmw e46 318i heater not blowing hot air?
you low on rad fluid? Most common reason.
May 08, 2014 | 2004 BMW 318i Touring
Hi i have a 318i bmw 2001 my fuel consumption is
Last month, my wife complained of high gas usage as well. I suddenly remembered that I had forgotten to change the air filter the last time I did the oil change. It had been over 5 months since I'd put a new one in. So, we got a new air filter, and monitored the usage, and it was back to normal again. Maybe try this?
Dec 01, 2010 | 2000 BMW 3 Series
Bmw 318i 2001 model just stopped while driving
you have problem with tank mybe is dirty and you must check fuel filter and fuel pump
Nov 22, 2009 | 1999 BMW 318 ti
Cant find blower motor resostor on bmw station
you must remove glove box,remove lower cover below glove box, get under dash and use flashlight and you will see the fan resistor in the evap box, it maybe held in with a t 20 torx screw otherwise pull aside tab and pull out
Oct 16, 2009 | 2001 BMW 325
1986 BMW 318i;Turns over but engine wont run.I'm
Fuel pump may be getting weak. If pressure is not high enough the injectors wont open.
Jun 27, 2009 | 1986 BMW 3 Series
BMW 318I WONT START.
sounds like crank sensor
Mar 29, 2009 | 1999 BMW 318 ti
Vehicle Parts & Accessories Logo
93 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
