Question about Sony Bravia Kdl52z5100 52 1080p Lcd Tv kdl52z5100 / Kdl52z5100
Turn on and turn off
TV turn on 30-60 sec....it will turn on and off until it will stop...when I turn on manually... It will turn on and off again... How can I fix this?
    Top Expert:
  • Sony Master
  • 74,377 Answers
Power supply regulator board problem. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on Apr 18, 2014
  • Chino Vivero Apr 18, 2014
    Tv it's turn on and display image is perfect...
    Add a Commentt will turn off and off 3-4 times
What are the codes to program the jensen remote to a sony tv?
to manually let the remote find the code as i couldnt find the actual sony code since you didnt list your tv try this proceducure
Turn on your tv manually.
Hold on to the (tv) button and on/off button for the same time for 3 secs.
On/off button will light up.
Push on/off button until the tv turns off. up to 30 or so times
Then push the stop button on the bottom of the remote tosave the config.
please let me know if that works
Mar 17, 2011 | Jensen 143307 Remote Control
Looking for codes to digital box
Turn on your tv manually. (without remote)
Hold on to the (tv) button and on/off button for the same time for 3 secs. (on remote)
Push on/off button until the tv turns off. (1x-10x) (on remote)
Then push the stop button on the bottom of the remote to save.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Jensen 143307 Remote Control
Cable/Analog Icon on screen
Usually the DISPLAY Button on your TV remote will toggle through several different functions: 1 sec, 5 sec, Always on..... Press button until display on TV is off. Or see if there is an ON SCREEN DISPLAY portion in the TV Menu and turn it to off if you have not checked that already.
Apr 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I need a code for a universal remote
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Mar 17, 2009 | RCA RCR450 Remote Control
Programing codes
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
Mar 11, 2009 | RCA RCR450 Remote Control
Can somebody tell me how to program a RCA 312w universal remote control to a emerson tv I have the intruction but I can not understand them thak you.
This will work with any devise and the rca remote.
1. turn on the device you want manually
2.press and hold the devise key, while holding the devise key press and hold the on off key till it stays lit.
3. point it at the devise and press PLAY for 5 sec. until it goes off. If it doesnt turn off after 5 secs. press and hold play again for 5 secs. repeat till unit turns off.
4. After unit turns off press and hold Reverse for 2 secs. until unit turns back on.
5. After it turns on hit STOP. and your done. Hope this helps.
Feb 25, 2009 | RCA Universal Remote Control
I need code for rca rcr461 universal remot my tv is a ilo
1. Manually turn on the component you want.
2.Press and hold the TV, DVD etc the illuminated component names turns on.
3.While holding the compnent key down simultaneously press and hold the ON.OFF key - the illuminated name turns off.
4. After holding down both keys for 3 sec, all components name stay on.
5.Release both keys. the component name remains lit.
6.Press and release the PLAY key, wait for 5sec, the component will turn off. If component does not respont continue to press PLAY every 5 sec until component turns off.
7.When the component turns off, then the correct code is blocked. Press REVERSE key wait 2 sec to see if component turns on again.
8. Once component turns on then use STOP key - now code is stored.
Note: use FORWARD KEY AND REVERSE KEY to go front and back on the code search.
(sorry for the typo (if any) I dont have a scanner to scan the manual and I am typing out from the manual)
Feb 13, 2009 | RCA RCR460 Remote Control
Dont have securtiy code to unlock tv
  1. Press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in.
  2.  Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
  3. Volume down on the unit and RH-Split on the remote-- same process
Try these one at a time until you find the right one.
Let me know if this helps and please rate this solution. Lone99star
Jan 18, 2009 | Panasonic TC-32LE60 32 in. LCD Television
Sony Bravia Kdl52z5100 52 1080p Lcd Tv kdl52z5100 / Kdl52z5100 Logo
50 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
