Question about Makita MAC2400 Electric Powered Air Compressors
Mac 5200 where is reset button
Makita MAC 5200 tried to start in cold weather now it will not come on. Cannot find the reset button
3 Suggested Answers
  • 1388 Answers
SOURCE: Makita MAC 5200 3 HP 5.2 Gallon electric compressor
Use non detergent air compressor oil. It can be found at Lowes, Homedepot, and even Walmart. It is sold in small containers for about $2-3 dollars. A synthetic blend air compressor oil is needed when the unit is used in severe conditions. Synthetic air compressor oil sold at Lowes $6.95 and other stores will take more heat. Second choice is 30w non-detergent motor oil. Engine oils tend to produce carbon on the reed valves in the head if used extensively. I have been using the Lowes Kobalt brand of air compressor oil for some years in my Makita and Rol Air compressors with good results. The part number for Makita brand of oil is 18112-A quart size. It is only available by special order where I live. Good Luck!
Posted on Feb 23, 2009
compman66
  • 169 Answers
SOURCE: makita 5200 Mac doesn't run
one of two things, either you have a bad start capacitor on the motor or a defective start switch inside the motor, either one can be checked at a electric motor shop
Posted on Dec 12, 2009
Mb324ll/a white screen
1.Try a Safe Boot
Mac OS X 10.2 and later Safe Boot includes disk checking and repair. First start your Mac in Safe Mode. To do this, shut down your Mac. Now Turn on your computer by pressing the power key while holding down the Shift key. When you see the Apple logo, release the Shift key. After your Mac fully starts, restart your computer normally without holding any keys/buttons during startup. Note that Safe Boot is slower to boot.
2.Run Disk Utility
Turn your Mac off by holding down the power button for a few seconds. Turn on your Mac and hold down the Command and R keys until you see the Apple logo. Then you should see a "Mac OS X Utilities" window. Select Disk Utility, click your OS X hard drive and select verify/repair disk.
3.Reset PRAM
This may fix your boot failure. PRAM ("parameter random-access memory") stores some of your settings. You may reset PRAM. To do that, turn off your Mac. Now turn on your Mac. Then, immediately, hold down the Option-Command-P-R keys until your Mac restarts. When your Mac is starting up, release the keys.
4.Reinstall Mac OS X
If nothing above works, you may try this. Your Mac needs to be connected to the Internet. See number#2 above. Follow the same steps. Restart your Mac and hold down the Command key and the R key until the Apple icon appears; when you see the Mac OS X utilities window, select the Reinstall option.
Mar 13, 2014 | Apple iMac A1224 20" Core2Duo 2.66GHz 2GB...
Restart appears on start up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 26, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Hi. I turn on the mac and the screen says Mac OS X then there is Name and password. How can I get in to the main screen?
If you do not know the password for the user, you can reset it very easily:
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  6. Enter a new password.
  7. Click Save.
  8. Click the red button in the upper left corner to quit the application.
  9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  10. Click Restart.
Aug 28, 2010 | Apple aluminum 13-inch MacBook laptop-...
I just set up the password on my macbook to get rid of a network settings problem and now the computer is saying i am putting in the wrong password!!!! I powered off the computer and restarted thinking...
Ok well try this... Resetting a user's password in Mac OS X v10.3 or later
Note: For information about resetting a password in Mac OS X v10.2.8 or earlier, see the Additional Information section below.
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" below.
  2. From the Apple menu choose System Preferences.
  3. From the View menu choose Accounts.
  4. Click the lock button if it appears locked; enter the administrator password.
  5. Select the username whose password you want to change.
  6. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  7. Enter a new password in both the Password and Verify fields, and add a hint if desired.
  8. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  9. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
    1. Enter a new password.
    2. Click Save.
    3. Click the red button in the upper left corner to quit the application.
    4. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
    5. Click Restart.
    After following these steps, you'll want to also follow the steps in this article.
Feb 06, 2010 | Apple MacBook PC Notebook
Makita 5200 Mac doesn't run
Dec 12, 2009 | Makita MAC5200 Electric Powered Air...
Mac Mini G4 turns itself ON
Have you looked into System Preferences>energy saver>schedule? Maybe it's set up to start itself. I have my mother's mac set to start up and shut down automatically. Just a thought.
Jan 09, 2009 | Apple Mac mini G4 Desktop
Blocked mac adress
Hey,
Try holding the reset button for a little longer, say for 30 secs.
Keep an eye on the power light and the power light on the router should start flashing.
Than release the button.
Mar 27, 2008 | Belkin (F5D9230-4) Wireless Router...
Printer driver for mac
There "may" be one possible solution, which people have had success at.
The Dell 922 printer is the same as a Lexmark X5270
Lexmark has Mac OS X drivers for their version of it.
If you have Mac OS X, the driver can be obtained here:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:440:0:0&searchLang=en&os_group=Mac%20OS%20X&target=
Mar 24, 2008 | Dell 922 All-In-One InkJet Printer
Makita MAC2400 Electric Powered Air Compressors Logo
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
